Old 09-21-2010, 02:13 PM
Brndo Brndo is offline
02 High Voltage Switch Squeak (Distributor)
It seems as if my High Voltage Switch (cap and/or rotor) is squeaking when I first start the truck. I can also feel a slight vibration when I put my hand on the cap. Squeaking goes away when I start driving. Does a bearing or something in the rotor go bad causing a squeak and vibration? Does this mean the cap and/or rotor need to be replaced? Parts store has one without module for $90. I assume I do not need the module as the truck runs fine. Has anyone had this happen before?
Old 09-21-2010, 08:43 PM
old_master's Avatar
Advisor/Moderator
Re: 02 High Voltage Switch Squeak (Distributor)
Distributor shaft bushings can wear but the driven gear, (on the distributor shaft) can also wear. If you end up needing a distributor, Dorman makes one that has an aluminum housing instead of plastic, lifetime warranty, and comes with the camshaft position sensor, distributor cap and rotor for $96.
http://shop.advanceautoparts.com/web...S_390547505___
Camshaft retard must be checked/adjusted after replacing the distributor, (requires a capable scan tool).
You have to know how it works,
to figure out why it doesn't.
Old 09-22-2010, 07:57 AM
Thanks a lot.
1.) So, would you recommend I replace it then because it is squeaking on start up?
2.) Do I have to replace the camshaft position sensor or just keep the extra part?
3.) After replacing the distributor, can I drive the truck to a scan tool (I don’t have one)
or, will that damage any mechanics or electronics?
Thanks again.
Old 09-22-2010, 03:19 PM
old_master's Avatar
Advisor/Moderator
1.) I would recommend diagnosing the problem before replacing any parts
2.) The replacement distributor is completely assembled, install and adjust.
3.) If camshaft retard is out of spec, it will set DTC P1345 and the SES light will come on. If the SES light does not come on, you can safely drive the vehicle to a shop that can check/adjust camshaft retard.
high voltage - 2000 rodeo 2.2L evinity Rodeo | Passport | MU 2 04-04-2006 05:48 PM
High Voltage! 89tracerman RX-7 0 10-04-2004 11:27 PM
High Voltage??? fatjay Corsica 2 09-09-2004 10:09 PM
High Voltage on '94 Dodge Grand Caravan Linda Caravan | Voyager 2 11-13-2003 05:22 AM
High Voltage tintagel S-10 1 11-08-2003 09:40 PM
Tags
blazer , dis
