Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-17-2010, 08:58 AM
DaChevyClassic DaChevyClassic is offline
Vent Harness Tube
Can I just clean my Vent Harness Tube on my 94 chevy caprice 4.3? Or where can I buy one from?
Old 09-17-2010, 09:10 AM
j cAT j cAT is offline
Re: Vent Harness Tube
why do you insist on this cleaning of the vacuum lines going to from the distibutor ? if these lines are 1994 rubber replace these lines.
the distributor check valve filter should be purchased at the dealership or a parts store that has a ac/gm replacement.
this distributor cap your installing ,,,is this from a scrap yard vehicle ?
Old 09-17-2010, 02:39 PM
before doing any work on this study this info at http://www.gmhightechperformance.com...ing/index.html
Old 09-17-2010, 03:44 PM
get it here :http://www.rmsautoparts.com/proddetail.php?prod=12555323
Old 09-18-2010, 11:03 AM
Blue Bowtie's Avatar
Registered Offender
The only thing in the vent array you may want to clean are the check valves. I would limit the cleaning to soapy water since the check valve membranes are rubber and may be susceptible to solvents. The rest is just rubber tubing as previously stated so you can either clean that out or replace it. The vent system draws its supply of clean air from the intake tract so make sure the hose connection to that duct is intact.
