Go Back   Automotive Forums Car Chat > Racing > Street Racing
Old 05-19-2003, 03:10 PM
z33_Tec z33_Tec is offline
Question Info on doing break stands
Ok, I was just reading about how to launch your car off the line the fastest and that with an automatic the best way is to do a break stand. Im just curious because I read alot of different things about doing a break stand. In all seriousness, how bad is it for the car? Can it really wreck your transmission? Or is it only bad if you do it for too long and cause heat build up? Im really new at this stuff so im sorry if this is a stupid question. The info on my car is: 2000 Cavalier - 4-cyl, automatic, front wheel drive. Im not exactly going for any big racing or anything but I like to have fun with friends now and then. Any info is greatly appreciated! :licker:
Old 05-19-2003, 03:32 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
you mean by holding down the brake with your left foot and stomping the gas with your right then letting it sit for a second of too then letting off the brake and u go flying forward?
yea that fucks up your transmission soooooooooooooooooo bad. my friend did it like 3 times and i did it twice (5 times total) and a week later his transmission went out. 98 integra with 14,000 miles on it. burns out the clutches on each gear (yes automatics have clutches...)
Old 05-19-2003, 03:58 PM
hakka's Avatar
hakka hakka is offline
I wouldn't recommend it for the setup you have. A brake stand is generally used to do a burn-out to heat the tires. In Cav, its probably pretty hard to burn out. If your intent is just to bring up the revs before starting, I still wouldn't do it. The front brakes of most cars are much stronger than the rears, so the are more prone to lock. In a rwd car, youy can push the brakes in part way and lock the front wheels, but allow the rears to spin, doing a brake stand. In a fwd car, you will lock the fronts and force the trans to slip instead...not very good.
Old 05-19-2003, 04:06 PM
mynismo mynismo is offline
yada yada yada
Send a message via AIM to mynismo
i've done it tons of times in my 240 with no harm. but then again it is a rwd.
and if it does go i have an excuse to do a auto>manual swap :flash:
438whp / 373tq - 11.9 @ 126
Old 05-19-2003, 05:33 PM
90gs's Avatar
on RWD i dont think its any worse than doing a burnout on FWD/RWD with a stickshift, but with an automatic and FWD i'd never think of doing a brake stand
Old 05-19-2003, 05:51 PM
Thumbs up
Ahh, thank you so much guys! :sun:
Old 05-19-2003, 06:09 PM
fatninja19 fatninja19 is offline
Send a message via AIM to fatninja19
power braking in a RWD car is effective because the brake bias is towards the front, so the HP can over power the rear brakes. You'd probaly break something if you power braked your FWD.
when in doubt, throttle.
Old 05-19-2003, 08:38 PM
yada yada yada
thanks ninja... actually i was going to ask the same question but must have forgot. you answered my questions too....
engine break-in thunderbirdcoupe89 Thunderbird 2 12-10-2009 01:22 AM
Do I stand a chnace against a 300zx N/A crx hf '88 - '91 Civic | CRX | Wagon | Shuttlee 24 07-05-2004 09:15 PM
Political compass - where do you stand? boingo82 Politics, Investments & Current Affairs 34 06-14-2004 03:52 AM
Where do you stand? carrrnuttt Politics, Investments & Current Affairs 7 03-16-2004 12:22 AM
Where do you stand? taranaki Politics, Investments & Current Affairs 31 05-15-2003 10:08 PM
