Old 05-18-2003, 09:12 AM
turbcivic's Avatar
turbcivic turbcivic is offline
Piston question
I can pick up another d15 cheap and can think of some evil ways to screw with people(turbo,turbo,turbo,nitrous) but will the eninge is out of the car, i can do a quick rebuild. What pistions or does anybody make pistions for the d15. Couyld i put some stype of other stock pistions in so that ist will raise the compression?
2007 dodge ram hemi sport-the tow/dd
1993 Civic HB-h22 with type s pistons, 125 shot, and some other goodies
1989 CRX(in the works)-h2b plus maybe some spray, or some boost
Old 05-18-2003, 12:05 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
hhmmmmm, if your gonna do something like that i would atleast swap a Z6/Y8 in it first... but give nopi.com a look thats where i got my high compression pistons from.....
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-18-2003, 12:10 PM
turbcivic's Avatar
When i said cheap, i meant for free. So i will have fun screwing around with the eninge to make it a sleeper. Plan on at least making 160 hp. High compression for nitrous or low compression for turbo, still haven't decided yet.
Old 05-18-2003, 02:44 PM
sparq's Avatar
sparq sparq is offline
AF Premium User
Send a message via AIM to sparq
Id worry more about the rods then the pistons...
AF's Official Asshole
RIP AUNIE
Old 05-18-2003, 03:14 PM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
You are all wrong. Let me be the ass and say "forget it!!" First things first, you cannot be cheap and have a turbo setup. Sure, you can get an HF manifold, a used turbo, yadda yadda. It will last maybe a week. Secondly, gunmen said it correctly, start with a 1.6. Even an Si motor, the 1.6 rods are a lot stronger than the 1.5. Another note, either route you choose, nitrous or turbo, you will want lower compression. High compression is for all motor.
Saying all that, if you wanna save money, this is what I would do. Find an Si motor somone is ditching for a B16, sohc vtec or something of the like. Pull it apart, put new rings and bearings in it w/ new headgasket, seals, etc. That is your best bet. If you wanna go boost or nitrous, get some forged rods, some lower compression forged pistons. This will bump up the price around $750. So, you think, the price is getting high don't ya. Ok, now you have a pretty solid bottom end for a nice RELIABLE build that will last you for the next couple of years. This setup will handle somewhere around 10-12 pounds of boost (more with blockguard and upgraded head gasket) or about a 75 shot of nitrous (more with upgraded SS valves). Of course, either one of these routes you take you will probably want to upgrade your fuel pump, injectors, ignition system. Holy moly, that is expensive.
You have just embarked upon what I was going to do about a week and a half ago. Until, I discovered that my crank was bad and it was gonna cost even more money. WOW!! So, now I am looking to get a B16 swap. Hmmm, 160 hp, factory reliability with a 350 like cult following. Something to consider if you can wait about a month to get one.
Hope I haven't ruined your party.
You could always just run about 5 pounds of cheap boost on a D15 which is easily and affordably replaceable. Sometimes, wish I would have stuck with that route. Have fun, don't get too serious w/ it.
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Old 05-18-2003, 03:37 PM
RedRacerCivic's Avatar
RedRacerCivic RedRacerCivic is offline
Send a message via AIM to RedRacerCivic
No way you are going to get 160 out of a 1.5 unless you spend over $2000. I spent $1400 to rebuid/build my 1.6 and it only pushes about 130hp with 11.0:1 compression. If you want to make that motor have 160hp, just buy a 50+ shot of N20 and have fun with it.
-1991 Civic Si (Sold)
-1990 Accord EX(Sold)
-2000 Civic Hatch
-1998 Lexus SC300
Click here to see my Shoe!
Old 05-18-2003, 06:03 PM
gunnmen01's Avatar
Yeah if you wanna go with cheap power...try all the bolt ones and then go with nitrious...its the cheapest bang for your buck....
gunnmen01
Old 05-18-2003, 07:10 PM
turbcivic's Avatar
I work at honda so when i say cheap that is what i mean. We have a bunch engines laying out back that i take parts off of. Read what i said again, free d15 that beats the helll out of my d15 with bad rings. I already have a z6 head sitting on my bench and wanted to see if there are other pistions that would work. I can got performance pistons at cost through honda and my and the two ther young guys go junkyard hoping. And i forget to add rods too.
By the way, from what i heard, if you want to run stricly nitrous then raise the compression, this isn't true?
By the way, this isn't going to be a race car, just something for me to screw with. My real love is still in car stero.
Old 05-18-2003, 11:44 PM
I have heard of high"er" compression motors running nitrous. However, you have to take into account a thingy called cylinder pressure. As the compression rises, so does cylinder pressure. Think of cylinder pressure as this, if you put so much air into a balloon it will rise to a certain extent. If you put that same amount of air into a slightly smaller balloon, POP!! Think of your cylinder as a balloon, sorry analogy I know. But as you raise the compression which decreases the "size" of the cylinder from the piston dome, you basically make a smaller balloon. As you add more air (boost, nitrous) expect a POP!! If you really want to run nitrous or turbo I would suggest lower compression. Sorry if this is confusing sounding. I really don't know how to say it well.
91 hatch Si
2001 integra gs w/ je 10.5/1 compression pistons question d_fl8ted1 Integra 1 09-28-2004 07:02 PM
je pistons question YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 16 01-06-2004 05:24 PM
better piston question YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 7 12-30-2003 07:49 PM
rods and pistons question for b20 YZ125rider21 '88 - '91 Civic | CRX | Wagon | Shuttlee 8 12-30-2003 12:16 PM
b18b piston question soul180 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 4 01-29-2002 05:41 PM
