Old 05-16-2003, 02:34 PM
KatWoman KatWoman is offline
7 speed automatic tranny - check it
From AutoIndex.org:
7G-TRONIC: Mercedes-Benz presents the world’s first seven-speed automatic transmission for passenger cars
Mercedes-Benz issued the following press release:
The world’s first standard-fitted seven-speed automatic transmission for passenger cars will make future Mercedes models even more economical and further boost their acceleration. In addition, the new transmission variant will also considerably enhance shifting comfort still further.
The new 7G-TRONIC seven-speed automatic transmission will be a standard feature of the E 500, S 430, S 500, CL 500 and SL 500 models from autumn 2003, replacing the five-speed automatic version currently fitted.
The newly developed seven-speed automatic transmission reduces fuel consumption in the NEDC driving cycle by as much as 0.6 litres per 100 kilometres (depending on the car), increases acceleration from 0 to 100 km/h by up to 0.3 seconds and allows significantly quicker intermediate sprints from 60 to 120 km/h. At the same time, shifting is even smoother, and therefore more comfortable, than with the automatic transmission presently used.
The Mercedes engineers have achieved these advances above all through the use of seven gear ratios. These allow the automatic transmission to retain the small increases in engine speed which are important in ensuring optimum gear ratios, whilst at the same time offering a larger ratio spread between the lowest and highest gear. This gives the electronic control unit more flexibility to adjust shifting in such as way as to keep fuel consumption low and the transmission’s reactions fast. What’s more, it also lowers the average engine speed – a clear plus point in terms of both cutting fuel consumption and keeping the lid on noise levels.
Fast gear-change using the principle of repeated downshift
When the driver switches down rapidly through the gears (kickdown), the new transmission does not always select the individual gears in strict order. Instead, 7G-TRONIC will miss out a particular gear if necessary, switching from seventh gear straight down to fifth, for example, and from there directly to third. In this situation, only two gear changes are actually required – instead of the normal four – in order to accelerate quickly using kickdown.
Shift quality, meanwhile, also hits new heights. The new transmission glides through the gears extremely smoothly and yet with impressive speed. Gear-change is barely noticeable, especially in the higher gears.
Torque converter lockup from first gear
As in its predecessor, one outstanding feature of the new seven-speed automatic transmission is a lockup clutch in the hydrodynamic torque converter. In many situations, this system largely eliminates slip between the pump and turbine rotor. It does this by establishing a virtually fixed connection wherever possible between the engine shaft and transmission shaft, creating an extremely effective barrier to output loss. In contrast to conventional automatic transmissions, in which torque converter lockup is only possible in higher gears, the lockup clutch in the new seven-speed automatic transmission from Mercedes-Benz is active from the first gear up.
Despite these significant technical advances, the 7G-TRONIC automatic transmission is barely any larger or heavier than the five-speed automatic transmission currently fitted in Mercedes passenger cars. Credit for this impressive achievement goes in particular to the transmission casing, which is constructed in lightweight magnesium – also a world premiere in volume production.
Mercedes has produced eleven million automatic transmissions since 1959
The 7G-TRONIC transmission development represents the fifth generation of automatic transmissions made by the Mercedes-Benz brand, and in so doing continues an impressive tradition. Since 1959, the Stuttgart-based car maker has produced over eleven million automatic transmissions. Whilst the automatic transmission is part of the standard equipment in the S-Class, around 88 percent of all Mercedes E-Class customers currently order their car with automatic transmission, whilst the figure stands at some 65 percent for the C-Class Saloons, Estates and Sports Coupés – and this figure is on the rise.
The new seven-speed automatic transmission will be produced at the Mercedes plant at Stuttgart-Untertürkheim, the original location of the company’s very first production facility. DaimlerChrysler has invested some 400 million euros at the plant in the construction of a new complex of buildings containing state-of-the-art production equipment and installations for around 1100 employees.
Old 05-16-2003, 02:38 PM
lordvektra's Avatar
lordvektra lordvektra is offline
thats cool. just pray it does not break Im sure it will cost a fortune to fix
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein (1879-1955)
Old 05-16-2003, 04:49 PM
jinushaun's Avatar
jinushaun jinushaun is offline
Send a message via AIM to jinushaun
So instead of CVT, they're planning on going 4->5->7->...->100 :hehehe: Maybe my understanding of CVT is off... :o
Jinushaun: Nation Leprechaun
Old 05-16-2003, 06:08 PM
2strokebloke's Avatar
2strokebloke 2strokebloke is offline
In Stereo where available
What about the million speed 1958 DAF? The first mass produced car to use a CVT.
Also about Mercedes claim (why anyone would want to claim to have "invented" a seven speed automatic T, is beyond me), I think that the Honda Hypershift, of the mid 1980s has already taken credit for this (O.K., so in reality it is only a semi-automatic tranny, but it still has the word "automatic" in it) Anyway, IMHO, CVTs are better, for both acceleration and fuel economy than regular auto trannys.
Support America's dependence on foreign oil - drive an SUV!
"At Ford, job number one is quality. Job number two is making your car explode." - Norm McDonald.
If you find my signature offensive - feel free to get a sense of humor.
Old 05-16-2003, 08:56 PM
badicalradical badicalradical is offline
dont mean to sound dumb but i will, whats CVT?
Old 05-16-2003, 09:11 PM
sidewinder69's Avatar
sidewinder69 sidewinder69 is offline
Tell me if I'm not correct, but I think it means: Continuous Velocity Tranny. Anyways, something like that.
It is employed mostly in Snowmobiles, and it just means that the tranny is always "shifting". Think of it as having a belt put between two cones, now when you push those cones together, you make the belt wider......it's hard to explain.
Anyone got a link to one of these pieces of work?
Later!
Aren't you that kid my older brother used to throw dog shit at?
Beamer:
http://www.facebook.com/album.php?ai...4&id=761900240
Old 05-16-2003, 09:32 PM
Sean Sean is offline
its basicly a belt between two cones. as the cones push together, the belt moves higher up on the cones and is the tighter.. or something
the tranny is pretty much constantly shifting. on the downside, there is no clutch or gear change noises
--------------------------------------------------- My signature line.
Old 05-16-2003, 10:35 PM
O.K. both of your explanations are lame. To put it into terms somebody can actually understand, the CVT transmission has two pulleys of variable diameter, that is the total circumference of the pulley can actually change. The engine side pulley starts out small, and the wheel side pulley starts out large, as the speed of the vehicle increases, the diameter of the engine side pulley also increases, while the diameter of the wheel side pulley decreases, effectively changing the "gearing" of the transmission.
Old 05-16-2003, 11:05 PM
boingo82's Avatar
boingo82 boingo82 is offline
Can't polish a turd.
Later!
It stands for Continuously Variable Transmission.
Just because offense is offered, does not mean you have to take it.
Old 05-24-2003, 12:31 AM
word
Old 05-24-2003, 12:45 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
I admit that I didn't read what was originally posted, but just going by the CVT comments, it's the same thing as the VTI engine in the Saturn VUE. It's really quite neat, IMHO, but what do I know?
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
FS: **$30 Shipped** 1995 Eclipse Turbo Automatic Transmission Motor Mount thakid22 Classifieds 0 12-17-2010 05:32 AM
