Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-31-2010, 03:34 PM
NINFan NINFan is offline
03 suburban e-brake failure
This car failed inspection last month because the e-brake didn't work. I replaced the shoes, but the cable was at the end of its adjustment. Turns out, after a little web searching, this is a common problem. I never did find an explanation, but it seems that it's fairly common for the e-brake adjustment to just run out on these trucks. I ended up tying a couple of knots in the cable to shorten it up, and it's working now. But it has me stumped - the cable couldn't possibly stretch so much that the e-brake doesn't work anymore. the shoes are adjusted to just barely rub against the drums on the rotors. Any idea what causes this condition?
Old 09-01-2010, 09:14 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 03 suburban e-brake failure
I would check the E brake shoe lining.
May be worn out or come off.
If needed they make E brake cable tightener.
MT
Old 09-01-2010, 09:43 AM
thanks, but as i said above, i replaced the e-brake shoes. i know about the tightener. i'm trying to figure out why this condition exists. i can't believe the cable could stretch that much, especially since we hardly ever used the e-brake.
2000 Suburban Brake Failure sk29 C/K 8 04-26-2004 09:34 PM
Warning!! Brake Failure!! filipnoy85 Tires and Wheels 6 02-20-2004 10:11 AM
'99 Suburban...Fuel Pump Failure Common?? SSuburban C/K 0 12-28-2003 04:39 PM
total brake failure gmcdan Sierra 1 12-19-2003 09:34 PM
Brake` Failure` please` help FuLL BLown STD '88 - '91 Civic | CRX | Wagon | Shuttlee 6 10-30-2003 07:28 PM
