Old 08-20-2010, 10:45 AM
CivicLeader's Avatar
CivicLeader CivicLeader is offline
Send a message via AIM to CivicLeader Send a message via Yahoo to CivicLeader
1994 K1500 - Diagnostic Code Reader - Which one?
Which Code Reader will work on my truck?
Old 08-20-2010, 11:47 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 1994 K1500 - Diagnostic Code Reader - Which one?
Well that is kind of a broad question.
Do we get a multiple choice?
OBD11 or OBD1?
OBD1 you can jump pin A and B and read codes from check engine light.
But some and with OBD11 you will need a engine spefic scanner to read computer or get codes.
MT
Old 08-20-2010, 12:32 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
1994 should be OBD-I. As stated by MT, you can jump the two connectors below the dash on the driver's side to make the ECM show the code by flashing the CEL. No scanner needed.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 08-20-2010, 03:41 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
94 may be missing a B terminal in the ALDL as a lot of the 94's were being phased into the beginnings of OBDII. So if you don't get the SEL flashes, don't get frustrated. You'll just have to find a scanner. Oreilley's and Advance have done it on my OBDII's, but they may not have the capabilities on an OBDI.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
