Old 05-14-2003, 11:29 PM
lambga lambga is offline
Angry 1989 Blazer firing problems
I have a 1989 Chevy Blazer with what sounds like an ignition problem. It has been in the shop for two weeks, they have determined that while on the scope it randomly will not fire a spark to one cylinder while running. The phenomenon is totally ramdom on which cylinder decides not to fire. The coil, wires, distributor, and other things have been replaced.....Anyone else had this problem? What is the cure????
Old 06-20-2003, 03:04 PM
S10Boy112 S10Boy112 is offline
I Have a 90 Blazer That had the same problem, i took it to the shop....turns out it was the distributer, 89 and 90 actually had a recall on the stock distributers, there is a replacement you can buy for under $100
1996 S-10 Blazer DTC Problem (P1192) arthurjohn Problem Diagnosis 17 02-16-2010 07:09 PM
1989 S-10 Blazer Wiring Diagram 89S10Blazer S-10 1 01-07-2010 10:01 AM
88 Sundance firing problems, won't run sundancer General Discussion 0 09-06-2009 11:02 AM
320i 1989 need firing order on dist. flippo2 3 Series 0 10-07-2007 01:16 PM
'90 Blazer Fires, but won't start USMCdad Blazer 3 12-10-2004 03:00 AM
