Go Back   Automotive Forums Car Chat > Plymouth > General Discussion
Old 11-04-2001, 12:08 PM
melbon melbon is offline
2.5 litre engine problem
would somebody please help in identifying why a 2.5 litre engine (chrysler) cuts out for only a second on and off at speeds of over 60 kilometers an hour. The car has only 60,000 miles and distributor and rotor have been replaced and wires to plugs replaced, but the problem still persists. I would appreciate any advice. Thanks Mel.
Old 11-10-2001, 11:45 AM
sched44 sched44 is offline
Possible that the fuel pump is shutting off or performing under par momentarily. See if there are any trouble codes logged in the computer. Given the age of the car, '89, there was a low fuel pressure problem. I believe the 89 model was the lower fuel pressure to the fuel injector. Chrysler later (I believe 1991) upped the fuel pressure to the injector. You can email me with more information if you wish as I don't usually view this forum.
Old 11-10-2001, 05:26 PM
1989 reliant k car
Thank you for your reply. I took all the wires out of the distributor and coil and made sure they were in properly, and I added fuel injector cleaner to the tank and it seems to have fixed the problem. Thanks for all your help. Mel.
1990 2.5 NO spark in plug #3 and #4 UseDaGreyMatter Lumina 10 11-29-2010 06:57 AM
Seeking 1991 carburetor for 2.5 litre gas Cherokee andy lucena Cherokee 1 02-12-2006 07:54 AM
'90 2.5 litre, died and has no spark decollect Lumina 2 12-23-2005 03:27 PM
2.5 litre ?????? 95milly25 626/Capella/Capella Wagon 0 08-03-2004 06:37 PM
1989 reliant k 2.5 litre engine melbon Engineering/ Technical 6 07-17-2003 12:00 PM
