Old 12-21-2005, 07:08 PM
decollect decollect is offline
'90 2.5 litre, died and has no spark
Hello again, I have (I hope) an easy problem to diagnose. Here goes:
'90 Lumina with the 2.5 litre, with about 150k on the engine. (315k on car) Was running just fine on an errand the other day. Car took daughter to her destination, but when she went to leave, the car would not start. Cranks just fine.
I hear the fuel pump pressurizing the system when you turn the key on, so I'm assuming it's getting fuel. I pulled #'s 3 and 4 plug wire off (not at same time) to check spark. Nothing on either one. I think it's highly improbable that BOTH coil packs would crap out at same time. I was told that if it is getting fuel, then chances are it's NOT the ECM that sits on the fender.
Is there another electronic module that is between the ECM and the coil packs? Is there a way to test the crankshaft sensor to see if it is the culprit?
Lastly, besides listening for the fuel pump, is there an easy way to tell if it's getting fuel, since there's no carburetor to look down into?
Merry Christmas and thanks for any help.
Old 12-22-2005, 10:49 AM
chris13174 chris13174 is offline
Send a message via AIM to chris13174 Send a message via Yahoo to chris13174
Wouldn't promise this is your problem but....
It sounds like you have a bad Ignition Coil. If you have a a manual for the car (can be bought at Autozone for around $20) it will tell you how to tests the ignition coils using an ohm meter. However, you may very well have a bad Ignition Control Module. You can have the ICM tested at Autozone for free. Hope this helps you out.
Old 12-23-2005, 03:27 PM
Re: Wouldn't promise this is your problem but....
I'll give that a try, I do have a book, and a pretty good digital ohmmeter. I should-a looked a bit better at de book. thanks.
Merry Christmas, Happy Holidays
