Old 08-03-2010, 12:41 PM
Technocrat Technocrat is offline
Question Runs Rough, only give 0300 error code
My sons pickup is a 96 Cheyenne 1500 with a 4.3 & Automatic. The problem stared day before yesterday, running very rough & backfiring. At that time it gave 0300 (general engine misfire), 0302 (Cylinder 3 Misfire), 0172 (Right bank rich), 0175 (Left bank rich), & 1441 (Evaporation collection system) codes.
We replaced the gas cap which eliminated the 0172, 0175, & 1441 codes.
The problem still persists with the engine running rough & backfiring through the tailpipe.
The only codes it will give are 0300 and occasionally 0302. I have checked the compression, it is good an all cylinders, average about 160lbs.
I have also cleaned the plugs & checked the wires. All seem to be OK. They have only about 5000 miles on them & are about 6 months old.
I have tried some Gumout Ultimate fuel system cleaner, suspecting some type of contamination, but have seen no change.
Any suggestions?
If the gas is contaminated, what is the best way to flush the system?
Old 08-03-2010, 01:05 PM
mastersat1 mastersat1 is offline
Re: Runs Rough, only give 0300 error code
The 0302 code means misfire on cyl #2. The last number corresponds with the cylinder. Try switching the plug and or wire to different cylinder to see if it is a plug/wire problem. See if code changes to that cylinder. Is this cpi(spider injection)? You could have random misfire from cpi unit. Also check real good for vacuum leaks.
Old 08-03-2010, 01:15 PM
I have done that, & am now only getting the0300. The engine has all new vacume hoses (In the last 3 months) & all of them are tight.
How do I tell if it is a CPI? It is a vortec engine with the plastic upper manifold & aluminum lower. The entire injector system is inside the plastic upper manifold. My Haynes Manual calls it a CSFI...
Old 08-03-2010, 07:47 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
I suspect a problem with the fuel delivery system. Have you checked to see if fuel pressure holds?
Also how are the start-ups, does the truck crank unusually long before it starts?
You could have a leaky fuel pressure regulator which is flooding out one bank of cylinders.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 08-03-2010, 08:23 PM
Not yet, will have to rent a gage. Where is the best place to check, under the hood or at the filter?
No, starts right off.
How do I check this? Can it be fixed or would the regulator need replaced?
Old 08-03-2010, 09:40 PM
tblake's Avatar
In God We Trust
There is a shrader valve on the fuel rail to check fuel pressure. If it doesn't hold, you need to find the leak. Whether its coming out the regulator and leaking into the manifold, or if its a sticking injector.
And the FPR cannot be serviced, its a remove and replace type of part.
Old 08-13-2010, 09:38 PM
Sorry for slow response. I had to get paid before I could get a fuel pressure gage.
Pressure is 58PSI then bleeds down (engine off check) & sits about 59 or 60 PSI at idle, the pressure fluctuates when idling. I have replaced the FPR, no change.
Old 08-14-2010, 12:50 AM
tblake's Avatar
In God We Trust
So you just replaced the FPR and no change to fuel pressure?
58psi is a little on the low side. With the engine off, turn the key on to prime the pump. Does the fuel pressure drop off immediatly?
If so you need to find out why the pressure isn't holding whether its a bad one way valve in the pump or if its a sticking injector.
Old 08-14-2010, 11:31 AM
Thanks for the quick reply.
Yes, we replaced the FCR & the fuel pressure still does not hold & did not increase.
Almost, say 2 to 3 seconds & it starts to decrease noticeably, about 15psi per second.
I had not thought of the pump. Would that make the pressure fluctuate when the engine is running? Is there a way to check the one way valve before we drop the fuel tank?
We thought of a sticking injector, & replaced the injector assy with one from another engine that was running when we scrapped the truck it was in. The symptoms have not changed. Either the second injector set had the same problem or the problem is somewhere else.
Is there a good means of checking the individual injectors? My Haynes manual does not give one.
Old 08-14-2010, 07:25 PM
tblake's Avatar
In God We Trust
On this motor there is really no easy way of checking the injectors short of specific dealer only tools.
Have you cleaned the MAF sensor? Use specific MAF sensor cleaner and a q-tip. Be carefull not to break the filiments.
Old 08-15-2010, 04:34 PM
I told you wrong on the pressure. I re-tightened my test gauge connection today & the pressure results improved somewhat. Engine off pressure is 65psi while the pump is running then drops immediately to 58 when the pump stops. After a few seconds the pressure starts to drop slowly to about 51 or 52 then holds pretty much steady.
Running it goes to 65 while starting then drops to around 58 while running, but still fluctuates a little.
Carefully cleaned the MAF with MAF cleaner & Q-tip, no change.
We even tried a new fuel filter thinking it would improve pressure, no change.
Does this still sound like a pressure problem?
If it does, can I check the one-way valve on the pump short of pulling the pump?
If not, any thoughts?
Old 08-15-2010, 06:10 PM
tblake's Avatar
In God We Trust
Fuel pressure sounds pretty good to me.
What year is this truck? When was the last tune-up done? If you listed it above, sorry if I missed it. And if it was recent, what brand plugs did you use? Hopefully not bosch.
I know if this is a 95+ truck, and the wires plug onto the sides of the distributor cap instead of the top, the later style distributor caps tend to have issues with cross firing cylinders.
Old 08-15-2010, 07:09 PM
OK
'96
[quote]When was the last tune-up done? If you listed it above, sorry if I missed it.[quote] About 3 months ago.
They were Bosch, P4s. This is the same plug that I have been using for the last 6 or 7 years in my other 4.3's with a cumulative total of about 500,000 miles on 3 vehicles without a problem.
People have told me the Bosch's were problems in the past, so despite my experience to the contrary I tried putting an AC plug (stock recommended for this engine) in the #2, along with a new wire since a 0302 is the only cylinder miss code I have gotten. This has been very intermittent, usually I just get a 0300. Anyway, the problem did not change.
Since the AC's are not expensive I will replace the other 5 just in case, (I have been wrong before) but I am not holding my breath.
The inside of the cap looks clean, with no spark traces. Can it short out inside the plastic?
Old 08-16-2010, 09:26 AM
tblake's Avatar
In God We Trust
Yes it can. If its the stock cap, you may just want to replace it just to rule it out.
Old 08-18-2010, 10:50 AM
ss#4 ss#4 is offline
did you get a chance to replace the cap?? I have a 99 that has to have the cap replaced every 9 to 12 months. Is there a fix to this??
