Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 08-02-2010, 01:47 AM
dapopes's Avatar
dapopes dapopes is offline
95 GM starting prob
Could an IAC valve be the cause of my 95 taking long time to start after sitting for a while (2hrs-overnite) or maybe fuel pump? Does fuel pump go out immidiatly or gradually?
Old 08-02-2010, 06:53 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 95 GM starting prob
Both could be the culprit, among many other things.
A fuel pump can go out gradually or suddenly. I've never experienced fuel pump problems, so I can't say first hand what the symptoms are.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 08-03-2010, 05:51 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Try to turn the key to the "on" p[ositions 3 or 4 times to see if it starts easier. If it does, it is a fuel related issue. Either a fuel pump getting weak, or possibly a restricted fuel filter.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 08-06-2010, 03:01 AM
dapopes's Avatar
Thanks for the reply. Yeah, the fuel filter's pretty new, so it's probably the pump gettin weak. Also, the idle speed fluctuates up and down quite a bit.
