Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 05-14-2003, 02:57 PM
coolbreeze229 coolbreeze229 is offline
Question Sports Cam Idle Problem
I have an early 99 Jetta Wolsberg Edition with the 2.0 engine. I upgraded the exhaust, added the chip, replace the airfilter with a K@N filter and replaced the stock cam with a 260 degree sports cam.
Thats when my problem started, the engine started to idle rough specially when there is no load from the A/C. I ended up replacing the Mass Air Flow Sensor, which did not improve the idle. I took it to the dealer and they claim that the Mass Airflow Sensor could not keep up with the Airflow demand due to the new cam. At operating speed the engine performs great and does have extra power. Does any one have any ideas on how to overcome this problem other then going back to my stock Cam?
Old 05-14-2003, 03:04 PM
SolTheHoelessPimp SolTheHoelessPimp is offline
Send a message via AIM to SolTheHoelessPimp Send a message via Yahoo to SolTheHoelessPimp
you realize that no matter what car and other modz, if you put in a hotter cam your going to get a rougher idle?
Old 06-06-2003, 01:34 AM
Obvious1 Obvious1 is offline
I dunno, 260 degrees is pretty tame. Did you get heavy duty lifters/followers when you installed your cam?
1997 Jetta GT, GIAC chip, Neuspeed CAI, ABD racing intake and short-shifter, 2.25" exhaust
"So as it turns out, Dave is a penguin"
Old 06-07-2003, 06:53 PM
AllMotor8v AllMotor8v is offline
Send a message via AIM to AllMotor8v Send a message via Yahoo to AllMotor8v
If you are getting a rough idle with a 260 cam, you might want to recheck the timing. Make sure all the timing marks (flywheel, cam gear, distributor) are lined up properly.
99 Caravan Sport Rough Idle and Stalling blase Caravan | Voyager 8 10-10-2010 07:48 PM
Clio 1.2 16v 2002 Expression idle problem!! stuuuu Clio/Clio II/Clio III 1 05-03-2010 02:59 PM
1995 SL Idle Problem peliknhed LS/LW 1 07-07-2009 07:30 PM
2001 Dodge Grand Caravan ES idle problem Rookie Tech Caravan | Voyager 3 07-03-2009 11:27 AM
