Old 07-26-2010, 01:27 PM
mikeso_81 mikeso_81 is offline
Front Rotor Replacement
Hi,
My front rotors are warped and are need of replacement. Fortunately, they are still under warranty so I'm going to replace them. Anyhow, my question is that do I just replace the rotors or should I clean up the brakes as well (grind off dust, compress the caliper piston, put new brake quite on the back of the pads, etc.) Note, the brakes are about 50% worn
2001 Pontiac Grand Prix GT 3.8L
Thx
Old 07-26-2010, 04:36 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Front Rotor Replacement
I'd but new pads and do it right. Your stopping distance and pedal force will be bad if you run old pads on new rotors.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-28-2010, 09:29 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with Tim, leaving old pads on that are 50% worn doesn't make much sense. Not only will stopping distance be affected reusing the old pads, but the chance of brake noise is significantly higher when reusing old pads with new rotors or vice-versa.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 07-28-2010, 09:37 AM
tblake's Avatar
In God We Trust
Not to mention if the Pads were overheated and cause the old rotors to worp, chances are the old glazed pads will ruin the new rotors.
Old 07-28-2010, 06:39 PM
GTP Dad GTP Dad is offline
Pontiac Guy
As tblake and richtazz stated replace the pads when you replace the rotors. The pads will seat better on the rotors and the braking power will be much improved. Pads are really inexpensive given their importance when stopping!
