Go Back   Automotive Forums Car Chat > Buick > Regal
Old 07-18-2010, 10:13 PM
andyf80 andyf80 is offline
1999 Buick Regal Ignition Switch Replacement
Hi guys,
I have found this wonderful write up on changing the ignition switch...
http://www.automotiveforums.com/vbul...d.php?t=653340
Unless I missed it - don't I have to remove the airbag/steering wheel as well?
Anyone done the repair before - Any Tips?
Old 07-19-2010, 06:24 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 1999 Buick Regal Ignition Switch Replacement
Welcome to AF
Yes I have and no you do not remove the airbag module or steering wheel.
Timeslip 08/12/06
AF Community Guidelines
Old 07-19-2010, 07:11 PM
Thanks so much! i'll let you know how it goes.
Old 07-27-2010, 06:42 PM
mn_1 mn_1 is offline
You'll need a E4 torq socket. Lisle makes one.
Old 11-14-2010, 10:34 AM
BNaylor's Avatar
Just an update.
Also, you'll need an E5 Star female extended socket for the screw(s) that hold the top steering column cover. And Torx T20 male bit for the two lower screws for the steering column lower cover.
I got my E socket tools at Harbor Freight Tools under the Pittsburgh name. Around $7.99 for the kit. See pic.
Timeslip 08/12/06
Old 11-15-2010, 03:37 AM
And watch out for an aftermarket remote start. Mine was spliced into the switch harness.
