Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 07-16-2010, 11:38 AM
killermrob83 killermrob83 is offline
motor mount removal
I don't really have any experience removing motor mounts. What is the correct procedure for removing the passenger side mount on a '99 CV with 4.6L? What I can see that looks possible is removing the through-bolt that keeps the upper and lower portions together. I don't see enough clearance to do anything beyond that.
Last edited by killermrob83; 07-16-2010 at 12:51 PM. Reason: additional information added
Old 07-16-2010, 05:58 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Re: motor mount removal
Check to see if there is a little bolt going down through the outside of the mount. Look down from the top to the outside of the mount. The through bolt comes out the front.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 07-17-2010, 06:34 PM
The through bolt is 10mm X 1.50mm X 90mm with tapered threaded end, and has a 13mm head. Passenger side come out from the front, driver side comes out from the rear. I was surprised how easily they came out after 200k miles in Michigan weather.
Last edited by killermrob83; 07-17-2010 at 06:35 PM. Reason: additional information
