Old 07-13-2010, 08:13 PM
Doug__las Doug__las is offline
stiff steering in both directions
Hi, I'm working on a 2005 Pontiac Grand Prix with a 3800 series III V6. It steers like the old standard steering cars. The reservoir is full and I don't hear any unusual noises. It looks like there may be some oil seepage at the bottom of the steer box (if that's what it's called). Does the pump have to be replaced or is there something else that can cause the problem? Thank you for any help that is given.
Old 07-14-2010, 03:11 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
Re: stiff steering in both directions
If the ps fluid is full, i would have to say maybe a bad rack and pinion.
Old 07-14-2010, 04:23 PM
Thanks for the reply. Is there anyway to test it? How hard are they to change?
Old 07-14-2010, 08:11 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
How many miles are on your car.
Another question, If you bring your car above idle, will it steer easier?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 07-15-2010, 07:42 AM
there are 80,000 miles on this car. never tried it at higher rpms. I will try it today.
Old 07-15-2010, 09:18 AM
Hi. I just tried the steering above idle and it steers easier than at idle.
Old 07-15-2010, 10:01 PM
tblake's Avatar
In God We Trust
Sounds like the pump may be on its way out or you have a kinked or restricted ps hose.
And the fluid level is OK, is it being aerated, has bubbles in it?
Old 07-16-2010, 12:08 AM
Doesn't have bubbles in it. I will check for a blocked line. Thank you.
