Old 05-13-2003, 02:03 PM
90civichatch 90civichatch is offline
Send a message via AIM to 90civichatch
Queston about MPFI
Why do you need a Si dizzy for MPFI?
1990 Honda Civic Shit-box, Sold.
Old 05-13-2003, 02:09 PM
91civicDXdude's Avatar
You can use an Si or an HF distributor. this is becasue the MPFI distributors have a Cylinder Position Sensor inside the distributor and the DPI ones do not. the reason for this is because the DPI manifold injects gas into a common plenum and gas goes to whatever cylinder has an open intake valve. the MPFI uses the cylinder position sensor to determine at what time to squir fuel into a cylinder at a given point in time.
Old 05-13-2003, 02:10 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Yes.
If you don't change to the SI dizzy, your engine will rev like mad when you let off the gas, and drop to idle when you step on it.
Which would be a great way to freak out anyone stealing your car, and perfect for keeping your mom from driving it.
Flunky
Old 05-13-2003, 05:03 PM
Yea, I know how MPFI works verses DPFI, but I didnt know about the cylender position sensor, thanks for the info.
I hope to be running MPFI soon.......
Old 05-13-2003, 05:32 PM
if you knew how MPFI works, you would know about the cylinder position sensor .....
confused about mpfi T-Mo '88 - '91 Civic | CRX | Wagon | Shuttlee 3 03-18-2004 10:03 PM
queston about an engine swap meiner MR2/MR-S 0 03-01-2004 05:39 PM
Queston about adding a second hidden battery.. Honda83 Car Audio 9 07-13-2003 01:36 AM
Queston about ractive exhuast.. Honda83 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 2 06-10-2003 10:05 PM
Questons About KYB AGX struts Honda83 '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 1 05-05-2003 10:15 PM
