Old 07-11-2010, 06:28 PM
CL8 CL8 is offline
Antifreeze in gas tank
Does anyone know what effect anti-freeze in the gas tank would have on a vehicle?
Thanks CL8
That if thou shalt confess with thy mouth the Lord Jesus,
and shalt believe in thine heart that God hath raised him from the dead,
thou shalt be saved.
For with the heart man believeth unto righteousness;
and with the mouth confession is made unto salvation.
Romans 10:9-10
Old 07-11-2010, 11:02 PM
curtis73's Avatar
curtis73 curtis73 is offline
Professional Ninja Killer
Re: Antifreeze in gas tank
Uh... bad. Antifreeze is heavier than gasoline, so it would sink to the bottom and have the same effect as if you put water in your tank.
Dragging people kicking and screaming into the enlightenment.
Old 07-12-2010, 09:11 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Just to elaborate...... antifreeze would not mix with the gasoline. It would stay separate, at the bottom of the tank. Your fuel pump sucks fuel from the bottom of the tank.
Therefore, it is quite likely the fuel pump would eventually suck-up some anifreeze and would travel through the fuel lines until it got to the injectors (or carburetor, in older cars). Then the engine would run extremely poorly, (if its just a bit of antifreeze) or stop dead. Then the injectors (or carb) and fuel line would need flushing and cleaning along with the gas tank.
FWIW I think antifreeze is worse than water. Modest amounts of water can be dispersed by the alcohol found in many regular gasolines (or by adding alcohol additive), so it will pass through the engine harmlessly. Antifreeze would be more difficult to disperse, I believe.
Old 07-12-2010, 11:13 PM
CL8 CL8 is offline
Thanks MR and Curtis!
Romans 10:9-10
Old 07-13-2010, 08:21 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The gas tank antifreeze additives are for small amounts of water, but being that its main ingredients (ethanol and isopropanol) is similar to antifreeze (ethylene glycol), there should be some dispersion action into the gasoline.
However, I'm guessing any more than a few (~4?) fl-oz of straight antifreeze in the tank would require the tank to be drained. I do not know the dispersion ratio of using an off-the-shelf gas dryer, and I do not recommend using more than one 12-oz bottle per tank since the stuff can affect rubber components and combine to form mild acids that can corrode metal tanks.
Others are welcome to give better info...hope this helps!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 07-13-2010, 11:15 PM
CL8 CL8 is offline
Thanks JD,
someone asked this on another site.
I don't plan on getting antifreeze in my gas tank!
Romans 10:9-10
