Old 05-09-2003, 01:16 PM
DArkforces9 DArkforces9 is offline
Send a message via ICQ to DArkforces9
When lowering your car.....
Do you have to get new shocks/struts especialy make for lowering your car?
Old 05-09-2003, 01:19 PM
91civicDXdude's Avatar
you dont have to, but your stock struts will blow out pretty quickly, as well as aftermarket struts if you lower too low. Just remember that if you lower your car, take it easy... dont drive on really bumpy roads or over railroad tracks if you can help it. anytime your strut gets to maximum travel and the strut "rod" hits the inside of the casing, it will blow your strut out and make it useless.
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
yes...new dampers are recommended but not necessary for about a month cause that's when ur stock ones will blow
depending on how much u drop depends on which damper will work best for u....
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
HOW TO: Lower your car the right way KustmAce Non-Performance 39 05-19-2010 10:51 PM
How to lower your car thatonesk8er Car Modeling 9 03-16-2005 07:32 PM
Amount you should lower your car nicholas9walter Off-Topic 11 03-20-2004 02:28 PM
Are coilovers good if you want to raise/lower your car at will? Toji Suspension 1 12-22-2003 02:14 AM
Are coilovers good if you want to raise/lower your car at will? Toji '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 8 12-14-2003 02:19 AM
