Old 05-09-2003, 10:48 AM
450HPviper's Avatar
450HPviper 450HPviper is offline
Question Turbo
What are all the parts that I need to put a turbocharger in my car?
Thanks,
Steve
Old 05-10-2003, 02:20 AM
ales's Avatar
ales ales is offline
Forza Schumacher
This is too generic a question, and the answer depends on a lot of things, like your goals, and the particulars of your car.
But to give you a list (which will probably not be full) of things that need to be changed or added to your car:
Turbocharger (compressor and turbine), intercooler, injectors, ECU, pistons, of course intake/exhaust totally changed from their respective ends up to the engine block, perhaps the block itself, external wastegate, bov, modified cooling and lubrication systems and quite a few smaller and/or optional thingies.
Old 05-10-2003, 04:49 PM
BeEfCaKe BeEfCaKe is offline
Yeah, depends on how much boost you plan on running.. I mean I've seen turbo cars w/o intercooler, pretty stupid I think, they run like 5psi boost? LoL
Old 05-11-2003, 05:55 PM
CAptynCrunch CAptynCrunch is offline
Hey, there's nothing wrong with low boost turbos Although you should intercool regardless.
Technically you can turbo any car you can get a manifold made for. On a stock engine not designed for boost you should be able to run around 6-8 psi of boost with an intercooler without much worries, unless it's a really weak engine.
Cheapest way to do it is to get a manifold, either buy one or have one machined, then buy a boost controller, then head for the junkyard!
Get a turbo off an old 80's saab turbo, grab and intercooler while your at it. Next your gonna need the piping, this shouldn't cost you too much. Other than that maybe larger injectors and some new gauges.
Given this won't give you incredible gains, but it's still a nice little power boost.
Keiichi Tsuchiya isn't the drift king,
Michael Schumacher Is.
The only thing better than cars is Music... maybe.
Old 05-11-2003, 06:07 PM
911GT2 911GT2 is offline
You don't NEED an intercooler. Fairly low boost engines don't (like the 1.8T or the Mazdaspeed Protege).
And you don't need to change all the internals either. Mazda didn't change a single thing for the Protege.
Some people deserve to have their vocal chords ripped out. Oh yeah, and American beer is like having sex in a canoe...it's fucking close to water.
Proud member of www.automobileforum.com
Mod -www.autoworldforums.com
Old 05-11-2003, 06:11 PM
You don't need one, but considering you can get one for $50 at a junkyard and it'll let you run safer and better, it's kinda dumb not too.
Old 05-12-2003, 07:04 AM
450HPviper's Avatar
I plan on getting an intercooler. My goal is to have 150Hp without blowing the engine up due to psi. I have a flowmaster muffler and a cone intake. I want to get bigger injectors, but don't know where to start to look for them.
I heard the ford 1.9 block can handle up to 12psi!!! Is this true?
Old 05-12-2003, 02:54 PM
I'm pretty sure I've read somewhere the Mazdaspeed Protege does have intercooler, though only a small one.
Old 05-12-2003, 02:56 PM
Sure you can pick up anything from a junkyard.. but I think most ppl would buy their own turbo, either new or fairly new... and considering they spent so much on it, what i'm saying is, it is good idea to invest in intercooler to enable higher boost, instead of wasting the turbo(and maybe even your engine)..
Old 05-13-2003, 10:14 AM
450HPviper's Avatar
I found a intercooler off a probe at the local junkyard and am going to go get it today after school.
Turbo Turbo...Im craving Turbo! Cavyfamous97 Cavalier 51 08-14-2007 04:25 PM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi JDM Motor & Parts info/chat 8 01-21-2006 01:11 AM
LS/VTEC Turbo, H22 TURBO, B20 Turbo....which one? 92HBsi N2O | Turbo | Superchargers 5 01-08-2006 10:40 PM
Turbos Turbos Turbos 4-THGENH24LUDE Prelude 8 12-23-2004 04:31 PM
Turbo, Turbo, Turbo SI_CivicGyrl Forced Induction 6 02-18-2004 01:47 PM
