Old 05-08-2003, 12:48 PM
CivicRacerX's Avatar
CivicRacerX CivicRacerX is offline
Send a message via AIM to CivicRacerX
Angry Climate Control issue
Background:
I got my car back from the shop (after a break-in) and the climate controls don't work right. The car sat for 3 weeks before I went home to pick it up, and the shop says it's too late, and that they can't verify if that damage was done during the break-in or since my parents picked up the car (this is such a lie). Anyway, I'm not seeking advice on this as I've already talked to my insurance company and called the Better Business Bureau.
The real problem:
My fan dial only turns the fan on if it's at the highest or next-to-highest setting. No local mechanic can diagnose it accurately (a couple told me the part they think I need is $250 and they can't guarantee the climate control is actually the problem), and I'm not really psyched about paying a dealership, so has anyone experienced this, or know what piece of the assembly I actually need to replace?
-C
96 Honda Civic Daily - H22 Swap
82 Renault R5 Weekend Runner - Nearly Stock
83 Renault R5 Track Car - 13:1 CR, Archer Cams
Old 05-08-2003, 02:53 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
my guess is your fan has either died, or there is a loose connection in the back panel, you might want to check that last one first, you'll have to remove the center console (prettymuch same procedure for removing your headunit) and just check the plugs going into the climate control, there should be 3 sets of plugs.. 1 for fan power/speed 1 for vent control, unless it's manual controlled be levers.. and the last for the heat controls, just turn your car on and turn the fan on.. and jiggle the cables, if the fan turns on, you just need to buy a new connector, or modify this plugs connectors so that it will work. if not I suggest you find the fan, and clean that thing out. It's probably dirty as all hell, and needs a good cleaning. next would be to pull it out, and hook it to a 12 volt source (power drill 12v batteries work great for this). and see if it runs. if not your switch is faulty, or there is a burnout/short in the wiring. best thing to do is get a voltmeter and test the wiring harness.. find the faulty wire, splice it, and run another wire..
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-09-2003, 12:03 PM
An interesting note is that when the fan DOES turn on, there's a suspect click by the glove compartment. I don't believe that it's a matter of dirt or a loose connection, but I appreciate the suggestion and I'll certainly double check those things. I'm going to pick up a multimeter this weekend and see what I can find out. Thanks again.
C
Unable to adjust climate controls..? ArdiniA Caprice 3 01-06-2010 08:05 PM
AC/Climate Control '02 Silhouette (Venture) andante147 Venture 0 06-24-2009 01:47 PM
Dual Climate control issue ccarbo Intrigue 0 01-05-2005 10:42 AM
climate control issues pgerald 6 Series 3 01-01-2005 08:14 PM
1995 Maxima GLE Climate Control Issues. TwilightBlue Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 0 05-13-2004 04:21 PM
