Old 05-07-2003, 11:01 PM
ndekens ndekens is offline
Torque steer or what?
I have a 95 civic ex with the d16z6. Whenever im driving my car pulls to the left. I know its not the alignment, and my its not my tires because its still the same when I have them rotated. So is it torque steer from the d16 that pulls me to the left?
:flamer: :eshooter: :rocket:
Old 05-07-2003, 11:26 PM
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
How do you know it's not your alignment? Torque steer from a d16 just sounds rediculous.
Old 05-08-2003, 11:17 AM
Cuz I said
I know its not the alignment because I had it aligned and they found nothing wrong with it. So I figured it might be torque steer because I was reading others posts that mentioned the D16 motors produce torque steer.
:bandit:
Old 05-08-2003, 01:20 PM
flylwsi flylwsi is offline
Send a message via AIM to flylwsi
all fwd cars produce torque steer, but only when you're flooring it.
if you're cruising at a regular speed, and it pulls left, it may be the road you're on, or the alignment.
get your tires rotated and balanced...
Old 05-08-2003, 03:49 PM
Deakins's Avatar
Deakins Deakins is offline
No they don't...
The ringing of the division bell, have stopped...
AF User Guidelines
Old 05-08-2003, 04:46 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
not all cars produce torque steer, you need some massive torque first, and the 80ft/lb hes putting out just aint gonna cut it.
you prolly dont have enough air in your left tire, so it grips more on the road, your alingment is prolly off, or you can be getting traction only on the left wheel, like your right is os loose gravel or something.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-09-2003, 04:27 PM
Frostbyte Frostbyte is offline
Send a message via ICQ to Frostbyte
Actually that is about the amount of torque my car is putting out. If you take my car to redline and then shift without holding the steering wheel the car will go off the road fast that is torque steer it happens more so when you take out the power steering like I have.
I just laugh my ass off when people talk shit on the D16's when there are some people out there have some kick ass D16's like my buddie Matt. I don't even know if there is anyone on this board that will be able to beat his D16z6 block with the y8 head.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
JIC Magic Front and Rear Strut Bars
Slotted and Cross-drilled Rotors
S/S Brake Lines
Pivot Lazy eye controller
Blitz LM Intake
Blitz D1 Spec Turbo Timer
Soon to come:
Sard 550cc Injectors
Blitz Nur Spec Exhaust
Blitz Down pipe
HKS FMIC
http://www.driftmonkey.com (Part Owner)
Old 05-09-2003, 07:00 PM
94tegRS's Avatar
94tegRS 94tegRS is offline
this guys d16 is stock tho, at lest he hasnt said that its not so im assuming. and yes probably anyone with a similarly built B16, B18, B20, H22 can beat it, unless he has it in a gokart
current
-84 datsun 720 4x4(2nd time)-93 accord-90 camry V6-90 warrior-94 300ex
history:
-01 R1-04 daytona 600-94 teg RS-95 teg LS
-91 teg RS-92 teg GSR-94 civic CX hatch (3 times)
-94 civic DX-96 civic HX-97 Accord LX-72 superbeetle
-74 beetle-84 silverado-66 c10-74 maverick-78 280z
-84 200sx-86 tercel wagon-95 mustang V6
Old 05-09-2003, 08:37 PM
B16EJ1's Avatar
I respect SOHC workers that go the extra mile like Bisi Ezeroiha and many others but you can't deny that a bone stock Z6 isn't that impressive.
Old 05-12-2003, 02:59 PM
Your right it's not you can still get a little bit of Torque steer out of the stock z6 but not like my car does now. I just wish I had all my stuff in a CX hatch.
1989 s13 Fastback
Tein HE coil-overs
sr20det swapped!
S/S Brake Lines
Blitz LM Intake
Soon to come:
Blitz Down pipe
HKS FMIC
