Old 05-07-2003, 03:09 PM
Deejay360's Avatar
Deejay360 Deejay360 is offline
Question Tamiya super glue
I am woundering will tamiya super glue leave white crap on a car???
Because I onced use super glue and did not know and it left white crap all over my car. I wounder will tamiya super glue do the same???
Tom
Old 05-07-2003, 03:21 PM
Veyron's Avatar
Veyron Veyron is offline
Smile
The only CA glue that I have found not to fog is Testors Model Master brand in the white bottle. If you shake the bottle and apply the glue sparingly it will not fog. Never tried Tamiya's though.
Old 05-07-2003, 03:33 PM
ales's Avatar
ales ales is offline
Forza Schumacher
PLease be careful with it. I have not used Tamiya superglue (actually, the only one I use now is Loctite Super Attack and I won't change it for anything... although Henkel's Moment is also good, but I'm not sure you can get it). Anyway, back to the point. I've never used superglue that did not leave "crap" as you call it on everything it comes in contact with. So use it sparingly (interestingly, the less you use the faster it dries and the better, sopposedly, the bond), and don't use it directly from the tube. Use a sharpened toothpic or similar, just to be on the safe side
Good luck!
Old 05-07-2003, 03:47 PM
TheSyndicate's Avatar
TheSyndicate TheSyndicate is offline
Avoid using cyanoacrylate on clear plastic. For clear plastic, use either 'clear plastic glue' (also known as model airplane window maker), or elmers clear blue school glue (works great! and cheap!).
Old 05-09-2003, 01:32 AM
theoldboy theoldboy is offline
my favorite
i use it on almost everything headlights being the main exception
the white crap you refer to is fogging and will usually occur because you use to much glue .stick to quallity brands though
Old 05-09-2003, 03:28 AM
CYPH3R CYPH3R is offline
I use TENAX on my kit but not on clear plastics...it will fog up and will never come off
Old 05-09-2003, 10:10 AM
Deejay360's Avatar
Thanx guys for the tips I dont think I will try to use the super glue I will try the other glues u guys use.thanx again.
Tom
Old 05-09-2003, 10:14 AM
freakray freakray is offline
AF Modelrater
Tamiya make a CA glue that the list as safe with clear parts, I am not able to give you an exact name on it right now or tell you more than that, you may find it on their website though or on an online model store?
It is always better to take the safest route though, just use some clear parts cement or white glue if you're uncertain.
Ray
AF User Guidelines
Old 05-09-2003, 01:14 PM
Valentino Valentino is offline
Tamiya made 2 kind of CA glue, the regular one and the fog resistant one.
The regular one did leave some fogging if used in clear part althought not as bad as another brand .
tamiya lotus europa special teszion Completed Projects / Gallery 12 02-05-2012 12:41 AM
