Old 06-21-2010, 09:59 AM
Scale-Master's Avatar
Scale-Master Scale-Master is offline
SilverState SuperTruck
Something fun, pure recreation build…I started with an R/M Chevy (Die-Hard in this case) kit.
The headers needed a mounting flange; they looked bland with no visible means of attachment to the engine. And there ware no provisions for spark plugs molded to the heads. I also added some locating pins made of stretched sprue at the same time to make installing them to the heads easier. Holes were drilled into the outboard pipes to accept the sprue. The flanges are made of .015 sheet plastic. The one on top is assembled, parts for the other below.
Here the pair is with paint...
I sanded off the molded in grille vents from the bumper/air dam and made receptacles for a pair of HID lights with brass tubing. (A lens is in the drivers side hole in this photo, from a Tamiya Morgan kit.)
The fan belt/pulley set is one piece, all it needs is some detail painting (and a little pin vise action...).
Old 06-21-2010, 12:04 PM
ridefast's Avatar
ridefast ridefast is offline
Re: SilverState SuperTruck
Every time I see a thread started by Scale Master I know some insane project is in the works... Just like this one.
Old 06-21-2010, 12:09 PM
gionc's Avatar
gionc gionc is offline
Authorized Vendor
Can't wait to eat more of it!
I try to come back by any trip and holiday with a "special" model: over 1997 sping I went to New Hampshire for job for a couple weeks and I found a graceful small model shop on Meredith, Lake district: I picked exactly the Die Hard Chevy racing Pick Up..... I wondered for years how to do the headlights before discover that they're sticker on Nascar cars (TBH I discovered on Cars moovie LOL)
So I'll follow wirth double attention, mine is still mint
gio
Old 06-21-2010, 03:33 PM
mike@af's Avatar
mike@af mike@af is offline
Captain Over Engineer
Great to see you're still alive, Mark! I actually was just talking about you yesterday when I saw one of those 3-Wheelers. I can't wait to see what you have for this project!
-Mike
Old 06-21-2010, 04:56 PM
Thanks for the kind words guys, just a little something to play with, can’t seem to find large enough blocks of time to build anything serious right now due in part to “those 3 Wheelers”.
This one will not be the Die-Hard truck, (which came with my decal art in the kit BTW…). I have been painting on the body, hopefully I’ll have something to show soon that will provide some insight as to what it will look like.
Old 06-22-2010, 10:42 AM
voyageur voyageur is offline
Oh, yeah. Just a quick recreational build. Aha. I guess that most of us will be drooling over that one. Already started very promising! Looking forward for updates. Have fun
Old 06-22-2010, 04:21 PM
The engine is coming together. A little texturing on the cast parts but pretty much mostly OOB.
I am keeping the oil sump system from the kit and doing some simple plumbing. The starter is also being wired. I machined an adaptor for the oil filter inlet from aluminum, but it will probably be out of sight once it is in the truck.
Old 06-22-2010, 11:45 PM
stump's Avatar
stump stump is offline
Send a message via MSN to stump
Ok, so this is NOT some ultra-rare 1/12 NASCAR styled truck you've stumbled across....??
Just had to ask to make sure, cause I didn't notice your over scale rule you usually add in...
This will be a stellar build Mark, glad to see you still keeping busy mate.
Hello, I'm Greg. I'm an Aussie and a compulsive model starter... http://public.fotki.com/Greg5000/
Currant builds...
1:12 Datsun Z432R
1:12 Datsun OS-Giken
Old 06-24-2010, 11:22 AM
The kit single 4BBL manifold was used as a base for an injection system. The big round plenum is just brass that was textured with paint. It has a dual ignition set up. The distributors are machined from scrap sprue. It is also plumbed for NOX. Just having some fun…
The engine is still growing. The ignition wires are ready to be routed to the plugs. Then the air cleaners will be installed… And maybe then the intake will make more sense…
I’ll see about including my “big ruler” later to prove it is me… - Mark
Old 06-25-2010, 09:29 AM
The body is coming along. Most of the paint work is done. This is all paint, no decals or transfers, but I did do some creative masking...
Tamiya lacquers for the paint. It will stay matte sheen.
Old 06-25-2010, 12:11 PM
Ferrari TR's Avatar
Ferrari TR Ferrari TR is offline
Not A Hoarder!
Interesting paint.
Silver State Classic Challenge? What's your target MPH?
SCCA 7, The lost Z
Old 06-25-2010, 12:15 PM
It's still in the experimental stage. As fast as a brick can go?
Old 06-25-2010, 06:42 PM
countach79's Avatar
countach79 countach79 is offline
lookin good!
Old 06-28-2010, 04:20 PM
The distributors and plugs are wired... Yep, only 8 plugs...
Here are the air cleaners I made for the engine. The bases are machined from aluminum. The elements are real foam.
And here they are installed...
Old 07-01-2010, 09:54 AM
I machined a few aluminum parts, a fuel filler and vent tube, and a pair of valve knobs for the nitrous bottles.
The HID lights are installed and the bumper is attached. I made reflectors with bulbs that are tinted blue. In some angles the blue comes through. Also added a screen grille.
