Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 06-12-2010, 03:52 PM
wildcatsua wildcatsua is offline
blend air door broken?
1999 camry 126k. A few days ago something happened that now the AC is always stuck on the face position. Turning dial to face/floor, floor, floor/defrost, or defrost has no affect on where the air comes out - it's always 100% out the front vents.
I took the switch out and checked with my fluke. Although the continuity between certain pins does not match what my Haynes manual says it still moves when the switch is turned. Conclude switch is OK.
I guess there's something called a blend door that is motor controlled?
Any ideas are appreciated.
Thanks!
Old 06-27-2010, 02:17 PM
Re: blend air door broken? / SERVO SUB-ASSY, DAMPER(FOR MODE)
A little more research leads me to believe the motor for this is actually called:
Anybody have any idea how to replace? Can it be changed without pulling the dash?
Thanks for any help!
Old 06-28-2010, 12:43 PM
somick's Avatar
somick somick is offline
On some cars servo motors are controlled by vacuum. Make sure you do not have a vacuum leak.
Have you checked with your car's FSM at www.carystuff.com?
Sam
Originally Posted by RIP
Please post back when you fix it so we all will learn something
Old 06-28-2010, 07:57 PM
Thanks but I think because the "Mode" switch is electric that it goes to an electric motor. Also, never heard a vacuum operated device called a "servo".
I'll keep checking.
Any other ideas?
Also, is there a typo in your link to carystuff.com?
thx
Old 06-28-2010, 09:06 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
See the link at the sticky post at the top of this forum for your service manual.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 06-28-2010, 10:12 PM
Thanks! Got the manual.
I checked the mode switch as instructed for continuity across certain pins as shown on page AC-85. This diagram is also in my Chilton's. I didn't get the results shown. But even when I plugged a jumper across the other side of the connector the mode didn't change. I assumed the Chilton was wrong but here is the official manual with the same pin diagram.
The switch is easy to replace but I don't want to waste money on something that's not broken.
Any ideas?
thx
