Old 05-05-2003, 04:57 PM
lowboy lowboy is offline
Send a message via AIM to lowboy
b16a vs. b18b
i wanted to contrast the differinces and similarities in these engines in preperation for a swap into my car.
which one would be harder to install over all?
i know the b18 would be a little cheeper, other than that are there and other advantages i might see?
which one would give me more power or feel better or is the answer obvious, with the b16 @ 20 mor hp?
thanks,
martin
Old 05-05-2003, 04:59 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Why dont you do both ?
B18 Block, with a B16 Head LS-VTEC!
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 05-05-2003, 05:48 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
well the ls would be easier to install wiring wise because u dont gotta wire vtec, but if your doing a mpfi swap anyways, its not that much harder to add the wires for vtec seeing as u have to add 4 wires for the mpfi swap.
but as far as mounting the engine and phsyically dropping it in, its just as easy
the ls has more torque and the b16 has more top end power. with the ls u can spin tire easy, gotta rev alittle higher to burn out with the b16. like with my friends ls crx like i was racing it and i had to launch at like 1500 and feathering the throttle all the way. i personally would go b16 but everyone has different opinions, u might want the torque of the ls
Team Lonely Drivers
Old 05-05-2003, 06:41 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Do a search and you'll find a few other threads that have asked the same question. You'll get a pretty good answer from the search.
Old 05-06-2003, 12:14 AM
2000dollarZCbs 2000dollarZCbs is offline
Send a message via AIM to 2000dollarZCbs
im with 90civicrider, go LsVtec all the way if you can, you have the advantages of both the top end power of the b16, and the torque of the LS motor, they are FUCKING great. my friend has one, BUTTTT<> make damn well sure if you do it that who ever does it knows how to do it, and drill it right otherwise you will be a VERY unhappy person.
poor mans type R!! go for it
Old 05-06-2003, 12:20 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Ls v-tec is not a poor mans type r.
Poor mans type r- b16/ gsr head mated with gsr short block with type r internals or type r short block.
Old 05-06-2003, 01:38 AM
i know i just think its funny cause i know the guy that invented it, and we trash on him about it.
Old 05-06-2003, 02:20 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
well im looking at some numbers right here, and i've got the b18 with only 10 more tq than the b16, is that right? if its only 10 how can this be any much of a difference, i was expecting 20+ the way you guys were talking
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 05-06-2003, 02:31 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Power is a product of torque and RPM The difference lies in where peak power is made. A b16a will make it's power higher up because it has the RPM advantage. Compare the power curves and you will see that one makes *some* power lower down while the other makes *more* power high up.
Bottom line? My B16A will smoke a B18B in similar trim any day of the week and twice on sundays. Go figure which is the better motor.
*** Removed rant about this thread only having been re-posted a million times... *grumble* search option *grumble*
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
b16a/b vs b18b/c vs h22/23 vs b20 FAQ KrNxRaCer00 Let's get Technical! 71 10-16-2007 07:15 PM
b16a vs. ZC vs. Sohc Vtec? QuickSilverEF9 '88 - '91 Civic | CRX | Wagon | Shuttlee 68 04-03-2006 02:58 AM
ok, B16A or B18B (si trany)? CBURKE '88 - '91 Civic | CRX | Wagon | Shuttlee 5 07-20-2005 06:56 AM
b16a or b18b defman JDM Motor & Parts info/chat 14 01-19-2005 02:31 PM
Turbo B16a VS Stroked B16a EF9JDM '88 - '91 Civic | CRX | Wagon | Shuttlee 28 09-03-2002 06:15 PM
