Old 06-03-2010, 05:20 PM
lazer2463 lazer2463 is offline
Exclamation 2004 GP GT2 3.8 with growing list of electrical issues
Hello and thanks for reading.
Let me first start with the power locks only working sporadically, with the drivers door working always.
Next the blower motor started working erratically, sometimes it wouldn't start working until you rap on the dash.
Now the latest is the horn stopped working all together.
Could these problems be related or are they totally seperate issues.
Could this possibly be the BCM failing? Or related to the aftermarket remote starter? Any help is appreciated.
Thanks,
2007 Chevy Cobalt 2.2
1999 Grand Cherokee, 4.0 I6
2004 Grand Prix GT, 3800 V6
1997 Chevy Cavalier 2.2
Old 06-04-2010, 06:29 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 2004 GP GT2 3.8 with growing list of electrical issues
For horn to start check the fuse and horn relay.
On the blower climate control issue is this a manual or automatic/digital unit?
The power door lock issue could be the BCM module but should be troubleshot to be sure.
Timeslip 08/12/06
AF Community Guidelines
Old 06-04-2010, 07:05 AM
Thank you for the reply.
I will check the fuse and horn relay.
The HVAC blower is a manual unit.
How would i go about troubleshooting the power locks?
You don't think it is the BCM?
Thanks,
Old 06-04-2010, 04:38 PM
BNaylor's Avatar
It could be the BCM but whats interesting is the driver's side door works. I'd double check to make sure the right voltage is getting to the other switches first. I'd have to check the GM service manual to see how the door lock switches are wired up. Do they lock/unlock with the RKE - key fob?
Swapping out the BCM is easy but the bad part is it has to be programmed by the GM dealership with a Tech 2 scan tool.
Timeslip 08/12/06
Old 06-04-2010, 07:43 PM
Hmmm.... The horn works now... did nothing to it.
The only door that will unlock with the key fob is the drivers door. Then I try to open the locks with the door switch, and that doesn't work either.
I really don't want to replace the BCM, I hope there is another explanation.
Could it be some sort of grounding issue?
Thanks,
Old 06-05-2010, 10:56 AM
BNaylor's Avatar
I'll check the service manual when I get a chance and get back with you.
Timeslip 08/12/06
Old 06-07-2010, 06:11 AM
Smile Re: 2004 GP GT2 3.8 with growing list of electrical issues
Thanks alot..... I'll be waiting to hear from you
Thanks,
Old 08-07-2010, 02:43 AM
jmad04 jmad04 is offline
I own an 04 GP GT2 and the blower stopped working as I put the car in park a few days ago. I pulled the blower motor/fan out , tested it, and it was fine. Could be what used to be called a resister but now is called module. Costs btwn 70 and 100.00. I am lowon cash till next week so I ran the blower direct and now it only works on high, but it works. Draw power from somewhere that functions on aux so you don't kill the battery or burn out fan. Be warned, I'm pretty below average when it comes to electrical.
Old 09-06-2010, 04:37 PM
Thanks for the replies.
OK, I took off the end of the dash near the BCM. Checked the plug and wiggled the wires around and everything started working again. I then wiggled the wires again and everything quit again. There are splices in the wires to the BCM for the remote start. They just have the insulation removed and the remote starter wires wrapped around them and taped, no solder. Looks like a poor install job.
Has anyone else experienced this from a bad remote starter installation? Could this be the cause of my problems? Should I just get the remote starter removed?
Thanks,
Old 09-06-2010, 10:58 PM
doctorhrdware doctorhrdware is offline
It is possible that is the cause of your problems. First thing I would do is solder the wires. It is not very hard thing to do. Then see if you continue to have the same problems. I think that should fix the original problems that you were having.
Old 12-22-2010, 09:21 AM
First I contacted Directed Electronics to see if the installation was covered under their lifetime warranty, here is the email.
"Directed Department: Warranty
Feedback/Question: I'm having a problem with the way my remote starter was installed by your authorized dealer, my mechanic found loose connections near the BCM. I'm having various electrical problems with my car that are related to the remote starter (locks and horn), and when the connections get wiggled the problems come and go. Does the lifetime warranty cover installation problems?"
Response from Directed,
No…………
Please read your owner’s manual to find the warranty Policy for this Alarm System.
Thank you
Great customer service, don't ya think.........
So, I contacted the installer and brought it in. They checked and soldered all connections and replaced my keyfob. Everything now works as it should.
So, don't count on customer service from Directed Electronics for any help.
Thanks everybody for your help.
Thanks,
