Old 05-30-2010, 12:51 AM
1986Z28's Avatar
1986Z28 1986Z28 is offline
Has a Camaro
Send a message via MSN to 1986Z28
Building a new 385ci SBC for my 1991 Z28
Working non stop to try and get the engine done for the summer, Vortec 880 roller 4 bolt main block, scat crank and rods, SRP forged pistons, Comp 280XFI, brodix heads, HSR etc etc....
Stripping the 355 i built last year.
Bare block.
Washed and out of the hot tank.
Polishing lifter valley and blending oil drainback holes, removing stress risers from the block.
Again
Formerly Blownalcoholboy
1986 Z28, 400ci SBC, Twin borg warner billet S467 turbos, Reid case powerglide, Moser 9". Holley EFI, Boost Leash. 950RWHP on pump gas, 1200rwhp on race gas (22 psi)
Best ET 1/4: 8.35 @ 170mph (275 drag radial)
Best ET 1/8: 5.44 @ 132mph (275 drag radial)
Best 60': 1.31 on the back tires (275 drag radial)
AF User Rules/Guidelines
http://www.automotiveforums.com/vbul...uidelines.html
Old 05-30-2010, 12:58 AM
1986Z28's Avatar
Has a Camaro
Re: Building a new 385ci SBC for my 1991 Z28
New ARP main studs installed to check the main line on the block, it needed an align bore no surprise.
Brodix IK200 heads, getting ported, and flowed numerous times, will post final flow numbers once i have them.
Removing casting flash
Had to weld the upper lip of the ports of the HSR to port to a 1206 intake gasket.
Shot of the welds
Rather than a hackjob mess of fittings, I drilled and tapped the underside of the fuel rails to install the pressure sensor for my gauge
Old 05-30-2010, 01:04 AM
1986Z28's Avatar
Has a Camaro
Porting the intake.
BBK 52mm TB, modified IAC motor housing, removed the coolant passage.
Porting the TB itself.
Scat 3.75" stroke 9000 series crank.
Scat 6" stroker I-beam rods.
Old 05-30-2010, 01:11 AM
1986Z28's Avatar
Has a Camaro
Weighing the rods for when i balance the crank.
The rods after being weighed, small ends honed to 0.0008" oil clearance, and ro bolt stretch done.
Pistons weighed for balance, pin bores honed to 0.0008" clearance aswell, Tolerance for balance is +/- 1g, these needed nothing out of the box, SRP forged -16cc dished, 0.040" over.
Balance card on the balancer. We use a CWT3000 balancer.
Cutting the main caps 0.010" for the align bore.
Old 05-30-2010, 01:15 AM
1986Z28's Avatar
Has a Camaro
Main caps cut.
Cometic MLS head gaskets.
Canton road race oil pan.
Old 05-30-2010, 01:27 AM
1986Z28's Avatar
Has a Camaro
Also, i work for a company called AMS engines, here is some of the stuff we do.
640ci Big cheif headed dual dominator BBC on the dyno.
Some circle track spec SBD's
Dodge Viper engine being shipped out to a customer
Another BBC.
Old 06-01-2010, 07:31 AM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
[drooling]
I envy you.
