Old 05-24-2010, 09:51 AM
FB1 FB1 is offline
2000 Z71 5.3 ABS issues
Both lights come on during most every drive and the check engine light has decided to stay on as well with quite a few codes. mild research has indicated a link between the two can anyone here help with verification of this? Also can the ABS unit be rebuilt? Is this in the harness or the unit. Thanks in advance I appreciate any help.
FishBobber1
Old 05-24-2010, 08:24 PM
j cAT j cAT is offline
Re: 2000 Z71 5.3 ABS issues
FishBobber1
with these failure lamp issues step one is GET THE DTC FAILURE CODES !
THEN POST back your findings...this will then get you started in taking care of the componet failures...
troubleshooting by using common failure componet issues is a crap shoot...............to guess at whats bad..
need codes .........
Old 06-14-2010, 03:50 PM
FB1 FB1 is offline
I finally got a list of the codes my truck is throwing:
[PCM] P0154 - HO2S Circuit Insufficient Activity Bank 2 Sensor 1 (SES)
(Old) (History) (Immature)
[PCM] P0155 - HO2S Heater Performance Bank 2 Sensor 1 (SES) (Old)
(History) (Current) (Immature)
[PCM] P0171 - Fuel Trim System Lean Bank 1 (Old) (Immature) [PCM] P0174 - Fuel Trim System Lean Bank 2 (Old) (History) (Immature) [Brake] C0245 - Wheel Speed Sensor Frequency Error (History) [Brake] C0265 - or C0266 EBCM Relay Circuit (History) [Brake] C0241 - EBCM Control Valve Circuit (History) [Brake] C0251 - (History) [Brake] C0242 - (History) [Brake] C0252 - (History) [Brake] C0246 - (History) [Brake] C0281 - Brake Switch Circuit (History) [Brake] C0269 - or C0274 Excessive Dump/Isolation Time (History
the truck has 186,xxx miles on the original drivetrain
i hope I'm not jinxing myself with this statement...
FB1
Old 06-14-2010, 08:45 PM
FB1
since you have the frequency error code I would check the front wheel sensor wires, also the voltage at the sensor connector when rotating the wheel ..with the wheel spinning by hand at a good rate you should get 450 MV AC >>>thats about 1/2 volt ac..then compare to the other front wheel should be close...
this may mean just a simple cleaning of the rust on the metal surface that the sensor sits on , or the wheel bearing is breaking down fouling the sensor pick up inside the hub bearing hole..
