Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-03-2003, 12:53 PM
hcivicron95
Guest
Posts: n/a
Exclamation Transmission
Ok for the past week ive been telling friends somthings wrong with my shifting. Its really rough to put into gear and somtimes it wont go and i step on the clutch like 2 times and it finally goes into the gear. There is no clicking or any wierd noises at all coming from the transmission. So what could it be?? Syncros?? or just the clutch?? Need to know soon, please help. Thanks
Old 05-03-2003, 02:34 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
in all gears? or just reverse? MIne is sometimes a pay in reverse.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-03-2003, 03:21 PM
hcivicron95
Guest
Posts: n/a
it has problems in perty much all gears when upshifting. 2nd is the worse because when i slow down to take corners ect. i usually downshift to second and its rough then also. its not a super big deal but when i take it to the shop il have him look at it.
Old 05-03-2003, 04:05 PM
k6kicker k6kicker is offline
Send a message via AIM to k6kicker Send a message via Yahoo to k6kicker
i'm not sure if you have a hydrolic clutch or not, but if you do i would check the fluid, if it is low, pour some brake fluid (same stuff, infact if you walk into an auto parts stre and ask for clutch fluid you will get luaghed at) and then happy shifting, if this isnt the case, i would guess either synchos or clutch
It sucks out there and I'm never going back
Old 05-04-2003, 01:07 AM
hcivicron95
Guest
Posts: n/a
um ok, thanks for trying to help. I guess ill just let the shop know when i get there whats going on. I just thought maybe someone has had this problem before and could give me a heads up on what it is before we take it apart and look at it.
Old 05-20-2003, 10:44 AM
Integris Integris is offline
Tranny
I'm having the same problem. Everyone I have spoken with says that the synchronizers are destroyed. They also tell me that it is much more economical to buy a good used tranny to replace it rather thatn rebuild the old one. I haven't had the money to do either yet, so I am double clutching! lol Cherry-Auto.com has the best prices on used trannies, though.
Old 05-20-2003, 11:50 AM
KrNxRaCer00's Avatar
KrNxRaCer00 KrNxRaCer00 is offline
Send a message via AIM to KrNxRaCer00 Send a message via Yahoo to KrNxRaCer00
its most likely that ur going to to be empty on clutch master fluid, an that ur clutch master cylinder and slave unit are shot. its not going to be the sycros, because if u can't even get it into 1st, gear, those only help WHILE DRIVING AN SHIFTING. it's the clutch master an slave unit...u can pick up the parts for around 150 i believe online or at a shop.
2003 Infiniti G35
99 Yamaha YZF-R6 (sold)
2000 Acura Integra Type R (sold)
1994 Acura Integra GSR (retired/sold)
Old 05-20-2003, 05:20 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
if it was low clutch fluid then you'd hear mad grinding if you tried moving it into a gear if the clutch wasnt fully engaged
Old 05-22-2003, 11:51 AM
GSR GSR is offline
Send a message via AIM to GSR
ditto...
how long since you changed the tranny fluid/oil? if you cant remember its been too long. try some Honda MTF, GM Synchromesh (the $12/qt kind), or B&M Syncroshift. you'll need 3 quarts a 3/8" drive ratchet and a 17mm socket. its really easy to do, you dont even have to lift the car.
looking for a 95+ 240sx in/near D F Dub area
Mustang Transmission part 2001 lawg8r Mustang Problem Diagnosis 1 04-13-2009 04:24 PM
Changing Transmission mkcody88 Accord/TSX/Accord Hybrid 2 04-05-2009 01:50 PM
h22 sh transmission used as a regular transmission h22 Prelude 1 07-31-2004 11:32 AM
?Transmission Fluid Needed for Manual Transmission? 85BlueGTI Golf 1 05-31-2004 08:21 PM
1988 Z24 Transmission problem, torque converter wont lock after transmission change Dale24 Cavalier 4 01-23-2004 02:29 PM
