Old 05-08-2010, 07:28 PM
jakegday jakegday is offline
Send a message via AIM to jakegday Send a message via Yahoo to jakegday
SES after changing plugs
hello. i just changed my spark plugs and wires today, and now my service engine soon light is on. the codes are p0108 and p0121. i have gone back and looked at all the wiring and nothing looks out of place.
any input would be most appreciated...
2001 Grand Prix GT: cat/u-bend/resonator delete, zzp PLOG, Custom Intake, DHP PCM,
1981 Fairmont 6cyl 3 speed
1978 Ford Ranchero GT 302 with a few goodies
Old 05-09-2010, 12:41 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: SES after changing plugs
P0108 is a MAP sensor issue. High input. Did you mess with the MAP sensor located above the PCV valve on the right side of the UIM plenum or PCV? Remove and re-seat the electrical connector to the MAP sensor to start. Also, make sure the MAP sensor is seated properly in the forked plastic retainer and accordian seal is good.
P0121 is a throttle position sensor (TPS) issue. Remove and re-seat the electrical connector to start. This DTC indicates the TPS is either stuck or the output is skewed.
Timeslip 08/12/06
AF Community Guidelines
Old 05-09-2010, 08:54 AM
MAP sensor question
hello all, i went to inspect my MAP sensor a few minutes ago, and found that it is 2 pieces.... is this normal?
Old 05-09-2010, 10:03 AM
BNaylor's Avatar
Re: MAP sensor question
jakegday,
Your two posts on the same issue have been merged together to cut down on confusion and possible redundant replies.
The answer to your question is no. Get it replaced.
Timeslip 08/12/06
Old 05-09-2010, 10:19 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Oops!
Did you lean on that while getting the back plugs?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 05-09-2010, 09:13 PM
lol, must have. a new one fixed the problem. the back plugs are actually ALOT easier then i thought they would be. hardest part of the entire job was pulling the back wires off
funny thing is the sensor was in that exact condition a few months ago when i changed the PCV valve, and it just now set a code..... must have bumped it just right
Old 05-10-2010, 08:55 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
The clip that holds the MAP in probably held it together enough to keep the code from tripping. Eventually, it started leaking enough to cause the light to come on. Glad to hear you got it fixed.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
