Old 05-02-2003, 06:22 PM
carey carey is offline
Unhappy my car is overheating...HELP!!!!!!!
I'm going mad...my car overheated on the highway..it wouldnt even start once I turned off....I s this my thermostat?...and if so could the blockage affect the starting of my car also.......THANKS!!!!!!!!!!!!
Old 05-02-2003, 07:52 PM
Black_97'Z's Avatar
Black_97'Z Black_97'Z is offline
Your thermo could be stuck closed. Or you could of blown a head gasket, check for white smoke out the exhaust, and a light sweet smell of coolant burning. Has your low coolant light ever come on? If no to the above pull your thermo out and put it in a pot of boilling water to see if it opens. Check you coolant level also. If your check guages light came on, sometimes the car needs time to cool off befor it will restart.
Black 1997 Z28 Convertible
Pic's Video
Old 05-03-2003, 12:33 AM
BlkCamaroSS's Avatar
BlkCamaroSS BlkCamaroSS is offline
Send a message via AIM to BlkCamaroSS
Also, check your oil level. If you're running really low, you're cooking your engine for no reason. Easy fix if it's just that...
2001 Camaro SS #2239 of 6332
1/4 mile time: 13.575 @ 105.55 mph, 60' time: 2.276
307.1 rwhp, 330.1 rwtq = 353.2 hp, 379.5 lb ft torque
Options: SLP Front Grille w/ SS Center Logo, 17" ZR1 Chrome rims, 6 speed, Hurst Short Throw Shifter, Monsoon 500 Watt Sound System, T-tops, 1LE Performance Suspension
Mods: Holley PS Air Filter, SLP Air Box Lid w/ Mr. Ed's pipe fix, SLP CAI, SLP Bellows, SLP LM, SLP Y-pipe, SLP 160 Thermo, SLP Temp Module, SLP STB, KBDD SFC
Old 05-04-2003, 01:53 PM
HiTechRedNeck HiTechRedNeck is offline
Bro, Check your coolant level . Look for any oil in the coolant. If it is very low ? Check your oil level. If it real high ? You need to dran the oil. Good chance all the coolant is now in your oil pan . There is a good chance you blow a head gasket. Other then that ! Replace the thermostat.
When you say you was driving down the road . Was you in stop and go traffic ? It could be your fan isnt working.
Who long had you been driving before it over heated ? 5 to 10 mins. Your stat might be stuck. Try tapping on the stat to see if will unstick. You can also make sure your coolant is full. And start the car. After about 5 mins you should beable to see the coolant moving through the radator.
When driving a auto. You always have to be awear of what your gauges are showing you.
If you give us alittle more info about the car from the first time you started it that day. And what all went on all day. It would help alot.
Old 05-19-2003, 02:00 AM
BullShifter's Avatar
overheating? no way
my 89 camaro had cooling problems, 1 thing went after the other. First it was the thermostat. Then the radiator had a small hole. After that the fan motor shorted out, taking the fan relay out with it. That was all in a 2 month period, then of course a new water pump. The only thing that hasnt been replaced on the cooling system is the damn over-flow tank luckily I was close to home or work so I didnt over heat to bad
the car is for sale
1989 Camaro RS 5.0L TBI auto w/ limited slip
Old 03-03-2004, 12:47 PM
dukecebrelli dukecebrelli is offline
Re: my car is overheating...HELP!!!!!!!
how much for the 89 camaro? im really looking for a manual tho
Old 11-03-2005, 02:54 PM
scharfschutzenss scharfschutzenss is offline
my 89 overheate after i broke the sepentine, drove it until the battery went, replaced the belt on the road, has worked great since with no probs.
Old 11-03-2005, 03:03 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Scharf,
If a thread is over 30 days old, make a new thread and link to the old one. Or in this case, if its over a year old its most likely delt with.
Its against forum polices to bring up old threads.
Just copy/paste a link into a new thread and/or Private Message the user you want to speak with.
Locked.
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
99 Civic Dx Overheating!! HELP sentoyang '96-'00 Civic 3 05-04-2010 09:26 PM
car overheating help racing#1 Let's get Technical! 0 04-02-2006 03:10 PM
Car overheating....help! FoRCedInDuKsionGsT Eclipse Problem Diagnosis 3 06-30-2005 10:31 AM
CAR Overheating. Help me out builtsable Sable 3 10-17-2004 02:19 PM
EEEK! Car overheated!! help..... Hybrid Boy '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 12-28-2001 01:08 AM
