Old 05-02-2003, 02:43 PM
DArkforces9 DArkforces9 is offline
Send a message via ICQ to DArkforces9
Headlight
My car sufferd some damage form the previous owner that bent the head light inward. My guestion is how do you take the headlight assembly out?
Old 05-02-2003, 03:27 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
remove the front bumper. then theres gonna be two screws on the bottom of the headlight bracket, and two on top.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-02-2003, 03:55 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
u dont need to remove the front bumper, its just hard to unscrew the bolts with it on but def. easier than taking off bumper, i just switched my stocks and my projectors yesterday, their all 10mm bolts just use an extension for the bottom one, the other one is on the side take off corner light.
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 05-02-2003, 04:36 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Ack... Getting that bottom bolt would be a huge pain without removing the bumper... I tried, but had no luck when I put my projectors in. And even if I did get the bolt out without removing the bumper, it'd be sooooo much harder to put it back in...
Old 05-02-2003, 05:00 PM
EF You's Avatar
EF Life Giver
dood, the bumper is like 4 bolts and 4 screws. dont mess your car up just cause you dont feel like taking the bumper off. those bottoms screws on the headlights are a bitch
headlights davidrobert2 Intrepid 1 11-20-2009 02:02 PM
changing sealed headlight system to composit headlights candywrapper Grand Prix 3 06-24-2004 10:21 PM
88 civic HB headlights----------> silvia s15 headlights iVteC_bOi 240SX | Silvia | 200SX(RWD) | Gazelle | 180SX 1 07-04-2003 05:47 PM
My cd player shuts off when i turn on headlights until i turn headlights off CrazyFukr2k3 Integra 1 01-30-2003 12:02 PM
