Old 04-28-2010, 12:37 AM
Drive24 Drive24 is offline
Question Power Steering Pulley Install
Had to take the power steering pulley off today. Sorta confused when it comes to putting it back on. The pump shaft has a hex opening on it when i expected to find a threaded hole. And the power steering pulley remove/installer only came with threaded bolts?? Do I need to get a hex fitting for the installer to work properly?
Old 04-28-2010, 09:20 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Power Steering Pulley Install
On inside the kex there should be threads.
MT
