Go Back   Automotive Forums Car Chat > Chevrolet > Chevelle
Old 04-24-2010, 03:01 AM
LV1 LV1 is offline
68 chevelle steering column
Went to a swapmeet today and found a steering column that look's to be the same as mine! While taking it back to the truck I ran into a fellow that told me that the column was out of a 67 camaro!
He thought that the inside componets would interchange with mine although, because the lower ends of the shaft are differant! Anyone know if the shift lever collar off the camaro would fit on the chevelle housing?
Old 04-25-2010, 09:57 AM
Blue Bowtie's Avatar
Registered Offender
Re: 68 chevelle steering column
Is Jefferson open already? I always miss the spring meet.
The die cast parts should interchange, even on a tilt unit. The shift tube, outer jacket, upper bowl, and steering shaft will be different, however.
Old 04-26-2010, 09:59 PM
LV1 LV1 is offline
Thank's Blue Bowtie, Jefferson was pretty good Friday! I built a clamp to hold everthing together on the steering column and took the top snap ring off, Then I pulled the 67 steering shaft and reversed with my 68. I couldn't believe how easy that was!! Plus, The backup lights work, and the neutral switch work's perfect without adjusting!! Bolted right in, Look's good111
Thank's again for the info.
Larry
Old 12-14-2010, 06:11 PM
Tony Silva's Avatar
Tony Silva Tony Silva is offline
Make it fit.....
