Old 04-16-2010, 06:38 PM
linda loo linda loo is offline
air conditioner 2003 grand prix
I need some real information on my car. The air conditioner runs cold, blows great but makes a noise like a playing card in the spokes of a kids bike. The higher you turn it up the louder it gets! You can hear more in the dash and glove compartment than under the hood
Took my first mini vacation four hours from home came back end ended up with two toilets broke and my car doing this! I also went to auto parts store and purchased two head lights one went out and the other went out at the inspection shop. When thay replaced them (for free) the brights are so dim you can't see them or there not working. I took the car back and I was told I need to clean lamps. Whats weird is they were extremley bright the night before and then the air starts messing up Help please It's warming up here in Texas and I won't use air till I know whats wrong.
Old 04-16-2010, 07:04 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: air conditioner 2003 grand prix
Welcome to AF.
It sounds like you may have debris in the blower motor assembly squirrel cage which is located in the area mentioned. You can either remove the blower to do an inspection or go in at the passenger side intake cowl. Most GPs do not come with a cabin air filter stock so check to see if you have one installed which should help keep stuff out.
Timeslip 08/12/06
AF Community Guidelines
Old 04-16-2010, 09:14 PM
Thank you very much for the help.
Old 04-17-2010, 08:18 PM
CrazyHorst CrazyHorst is offline
it is a possibility you have the wrong bulbs being used...with the high beam filament having too much resistance or an improper pinout.
You could probably take your bulb(s) to an auto parts store and look thru their paper catalog selector...see what the various cross references for the manufacturers are and compare to what you have. You can probably also compare right and left if there is one working and the other not.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
