Go Back   Automotive Forums Car Chat > Chevrolet > Venture
Old 04-16-2010, 02:58 PM
baby141 baby141 is offline
Found Leak! -2002 Venture
So today I went to run some errands. Low and behold there was a puddle of green stuff under my van. It was at the back (driver's side, directly behind the back wheel). So I take a peek underneath to see where it is coming from. There are three hoses/pipes that seem to run from the front to the back of the van. The one that is leaking is the hose closest to the back tire (driver's side). I hope I'm being clear in my explanation. I did take a pic because it doesn't seem to leak all the time and the last time I took it to the mechanic it had stopped and dried up and the mechanic couldn't see a thing. Does this still sound like a coolant leak coming out of a hose from the back of the van? Please help.
Old 04-16-2010, 09:19 PM
roadrunner2 roadrunner2 is offline
Re: Found Leak! -2002 Venture
It's likely a rear A/C coolant line.
Seeing it's under pressure you may have to replace the line.
The problem with doing nothing is not knowing when you're finished.
Old 04-18-2010, 11:44 AM
lesterl's Avatar
lesterl lesterl is offline
Was the green sticky/ oily if so then AC Oil, if it was watery like koolaid, then antifreeze and someone has switched you to the green stuff (look in radiator to confirm).
1997 Chevrolet Venture SFI 3.4l Auto 249k
2006 Chevrolet Malibu Maxx SFI 3.5l Auto 81k
http://www.s10forum.com/forum/attach...nsor-chart.gif
Old 04-19-2010, 08:08 PM
BradyBizzle BradyBizzle is offline
http://www.automotiveforums.com/vbul....php?t=1011673
I believe we have the same problem! See Photo....
