2000 GTP rearview mirror replace
Into the auto-dim mirror replacement (it fails to dim)
The factory manuals instruct the use of a small screwdriver...but no indication where... An older AF post suggested just pull up and release the dovetailed slide w no tools needed. I just don't want to break the windshield ![]() I have tried pulling and gentle taps w a small plastic deadblow hammer in that direction (up) with no luck yet. Thanks in advance for tips...
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) Last edited by CrazyHorst; 04-07-2010 at 08:39 PM. |
Re: 2000 GTP rearview mirror replace
The manual-dim mirrors need a little allen or torx to get off, the auto dim ones just push upward firmly at the base of the mirror, it should pop off. Not the best design IMO.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Heres what I did, got a smooth faced framing hammer and wrapped it carefully in a doubled up thin cotton rag. I did this so i could slide the hammer head along the inside glass without scratching. The slightly firmer blow did the trick.
The new Gentex mirror used a T-20 torx button-head screw which was easier. Thanks for the help!
1988 Chevy R-30 1 ton DRW pickup (217k) 1991 Chevy S-10 4WD pickup (192k) 2000 Grand Prix GTP (218k) 2002 GMC Yukon (185k) 2009 G8 - GT (46k) |
Hi there...I bought the Gentex K2 auto dimming mirror from AutoAnything.com. Not sure if that was the best price but good enough for me. There are OEM Donnelly parts on ebay but I found those used and wasn't willing to take the risk.
There are 3 wires coming down from the GTP harness pigtail to the mirror. White Black Green. I metered out the White to be +12vdc switched to ignition and Green to be the ground. I simply spliced the GTP harness and the Gentex quick connector (only 2 wires needed...trimmed the black wire higher and insulated) with solder, taped and slid back inside the GTP wire organizing clip (plastic part). All of this and added approx 2" to the OEM GTP mirror harness. I had it out early this morning at 0345 and it appeared to work great - self-test before that by blocking the forward-looking photosensor caused a visible dimming effect. The longest part of the project was not wanting to destroy the windshield in the process. Wiring etc was approx 1/2 hr. Easy afternoon project.
I've got a write up in the tips an maintenance if you guys need any more info.
