Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 04-07-2010, 10:06 AM
|WYG|SS |WYG|SS is offline
95 camry le cruise control problem
on my 95 camry le 2.2l and i want to fix my cruise control. when i hit the switch nothing happens, no light nothing. what could be the problem?
Old 04-07-2010, 08:03 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 95 camry le cruise control problem
Check the cruise control actuator connector is tight. It is on the side of the cruise control actuator at the front of the engine compartment.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 04-09-2010, 09:12 AM
could the motor not working cause nothing to happen? is their anyway to take the motor off and test it?
Old 04-09-2010, 01:07 PM
Brian R.'s Avatar
Resident Chemist
Did you check the actuator connector? That is by far the most common source of this problem.
If the indicator light is not blinking and it is not a poor connection at the actuator connector or wiring, then it is either the switch on the stalk, the cruise control ECU, or the actuator itself. Download the '94 Camry FSM from the link stickied at the top of this forum and diagnose as shown on pages BE-202 (switch), IN-36 (CC ECU), and BE-190, BE-192, and BE-196 (actuator).
Old 04-10-2010, 06:12 PM
well check the accuator it is good and the moduale it is good also so it is switch. how would i go by replacing this or would it be easier to get a universal switch and just splice it into the existing wiring?
Old 04-10-2010, 08:58 PM
well it was the switch as i took it out the wires were breaking off the harness.
