Old 04-01-2010, 07:48 PM
thecrow1986 thecrow1986 is offline
2002 grand prix stumble
when i get in the car hot or cold it doesn't make a difference. ill start driving and it doesn't make a difference if im going fast or slow. when i reach about 50 mph it kinda stumbles . not sure what this is. i have 222000 on it and had changed the plugs and wires and cat and fuel filter and had a fuel system cleaning done. the transmission was serviced last june. nothing has helped this go away. could it be injectors or something else like transmission?
Old 04-01-2010, 09:58 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: 2002 grand prix stumble
It could be injectors, but I would check for a vacuum leak, then unplug the MAF sensor and start it to see if it still stumbles.
What brand plugs did you install?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-02-2010, 09:17 PM
where should i check for vacuum leaks? i took the maf off and the throttle and cleaned it with the cleaning spray that is recomended but it didnt help. one thing that i have noticed that i was reminded of is sometimes when i start my car i hear like a kind of thunder from the rear of my car. could it be the fuel pump dieng out? this seems to happen more when the car has been running around
ac delco iridium plugs and wires
Old 04-02-2010, 10:30 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
When you press the gas, do you feel a lack of power compared as before? Like if the pedal is more easy to press. If you put gear in neutral or just release pedal, it makes a difference?
If not, I think it might be a lack of pressure in tire. Check pressure on all tire. Maybe a very small flat that you need to seal.
But no, it's not the plugs.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 04-05-2010, 12:39 PM
rkvons's Avatar
rkvons rkvons is offline
I gotta say, I lost my way after getting to this reply...
Old 04-05-2010, 12:52 PM
One time I get a small air leak in my tire. So when I exceed 55mph, all the car stumbled. Not the engine, but all the car. When I changed the bad tire, problem was gone. I was able to go to 95mph (above the speed limit) w/o any problem.
But if the problem is on the engine, tests must be done to the engine. Like release the gas or put in neutral when it stumbles to see if it reduces. Cause the engine is unbalanced if a cylinder lack of power. Advanced test can be done on the engine.
Old 04-09-2010, 08:20 AM
do you think maybe i might need a new fuel pump? sometimes i hear a rumble coming from the rear of the backseat when i first start the car
Old 04-09-2010, 08:29 AM
Maybe. Test the fuel pressure.
Old 04-09-2010, 08:30 AM
im gona see about testing it today
Old 04-09-2010, 06:27 PM
CrazyHorst CrazyHorst is offline
I think with 222k changing the fuel pump is just a very good step in the right direction to keep you from walking home!! Sounds like you have crossed off some of the more common ignition and induction problems.
The other thing i would consider is the crank sensor...both fuel and ignition pulses are based on this signal -- known weak point of 3800s. And also another walk-home problem...so something good to change as a maintenance item.
1988 Chevy R-30 1 ton DRW pickup (217k)
1991 Chevy S-10 4WD pickup (192k)
2000 Grand Prix GTP (218k)
2002 GMC Yukon (185k)
2009 G8 - GT (46k)
Old 04-21-2010, 09:00 PM
where should the pressure be at. i tested it the first time and it said 46. then i tested it again and it kept bouncing back and forth from 44 to 46
Old 04-21-2010, 09:17 PM
On this car with 3.8L, it should be between 48-55 psi (steady) when engine is off.
When engine is idling, it should be between 38-52 psi. It can fluctuate a little bit while running.
Old 04-21-2010, 09:35 PM
grandprixgtx00's Avatar
grandprixgtx00 grandprixgtx00 is offline
Send a message via AIM to grandprixgtx00
If you drive the car with the gear position in "3" (turn OD off) does it still do it? I'm thinking more along the lines of a bad TCC. 50mph is about where it should be going into OD
Old 04-22-2010, 07:24 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
I agree with the TCC issue, 50 mph is right where the converter will lock. With the noise from the tank the fuel pump isn't out of the question, but a pump can be noisy and still work fine. The pressure readings are within spec as real world fuel pressure specs on these cars is more in the 42-48 range, regardless of what specs sheets say.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
