Old 03-31-2010, 08:35 AM
Nbr1slr Nbr1slr is offline
Trans lines to radiator
Is a special tool needed to disconnect trans lines at radiator??
Old 03-31-2010, 09:41 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Trans lines to radiator
There is a tool to make it easier but you can remove the plastic cover, use a pick to remove the metal clip (they go flying and disappear if your not careful) and then remove the line. You can reinstall the metal clip before reinstalling the metal line or after you install the metal line.
Old 03-31-2010, 09:21 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
New lines should come with a new clip but if you are carefull they shouldn't go flying.
I could have swore the trans cooler lines were just regular nuts on both ends (trans and radiator). I didn't think they had these little clips.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 04-01-2010, 12:13 AM
GregGP GregGP is offline
They are there.. Aggravating as hell, but they are there.
SAMSUNG-SGH-A867/A867UCHJ3 SHP/VPP/R5 NetFront/3.5 SMM-MMS/1.2.0 profile/MIDP-2.0 configuration/CLDC-1.1
