Old 04-28-2003, 11:49 AM
cscott784 cscott784 is offline
Send a message via Yahoo to cscott784
Thermostat installation
HEllo. I wrote a thread about my car overheating and it was recommended that I first replace my thermostat. Does anyone know where I can find a tutorial to help me do so. Also, how long does it take. I would like to do it during my 1 hour lunch.
Thanks
Scott
Old 04-28-2003, 02:08 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
Get a Helms or Chiltons book. It's pretty easy but you need to drain he radiator.
Old 04-28-2003, 03:25 PM
sastanley's Avatar
sastanley sastanley is offline
AF Premium User
Send a message via AIM to sastanley Send a message via Yahoo to sastanley
If you have $60 - get the real Honda manual (sold by Helm as stated above) www.helminc.com
However, for easier tasks like a thermostat, a Chilton's will suffice - they are about $20. Now that I have the real Honda manual, I don't even know where my Chilton's went.
You'll need a pan to collect the antifreeze...you could get away without actually draining the radiator, but you'll still need to collect what pours out of the upper radiator pipe when you remove it to get to the thermostat (the thermostat is right where the upper radiator hose connects to the head) If your collection pan is clean you can re-use the antifreeze, since you don't want to just toss it in your local storm drain...or bottle it up and take it to the same place you return used oil. When you put antifreeze back in, mix it 50/50 with water..unless you buy the pre-mixed. There is also a process for bleeding the air out of your cooling system too, but I recommend you get a repair manual.
Don't forget the $0.50 gasket when you buy the thermostat....otherwise antifreeze will most likely leak from the housing when you put it back together...and take some time (using a razor blade) to clean off the old gasket but be careful to not scratch up or gouge the metal you are scraping.
You might be able to do it in an hour, but you may also want to have alternate transportation as a backup plan in case you don't finish it.
-Shawn
'91 Civic DX sedan
DOHC ZC, I,H,E, urethane bushings and mount inserts, rock chipped hood, some rust, stock steelies, nice comfy Integra seats, and the A/C works! What else could you want from an 18 year old car with 241,000 miles? Working on getting the Si tranny in now
Old 04-28-2003, 03:38 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
Just follow the lower radiator hose to where it connects to the engine. Take off the 2 bolts on that housing and inside it is the thermostat. Just pull the old one out and pop the new one in. Make sure to get a new gasket when you do this. You don't need to drain the radiator but stick a pan or something to catch all the crap that leaks out. Then just run the car and fill back up the radiator.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-28-2003, 04:59 PM
civicHBsi91's Avatar
civicHBsi91 civicHBsi91 is offline
Send a message via AIM to civicHBsi91
you mean lower radiator hose..........
2002 Acura TL Type S
1991 Honda Crx Si
Old 04-28-2003, 06:41 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
hmm i thought it was upper too. lower does not make no sense because then coolant wont be flowing through the engine beacuse it stops right at the engine but doesnt go through it. but acutally after thinking about it, yeah lower
Team Lonely Drivers
Old 04-28-2003, 08:04 PM
the upper hose just goes str8 into the head.......nothin there cept a gasket for that piece
1991 Honda Crx Si
Old 04-28-2003, 08:29 PM
Follow the lower hose off the radiator and you'll find the thermostat. Thats why you have to drain the radiator.
Old 04-29-2003, 12:40 PM
Great! Thanks alot guys. I just bought another 90hb so It wont matter if I finish today or not.
THanks
Scott
Old 04-29-2003, 02:22 PM
sastanley's Avatar
AF Premium User
Ooops...so I do...thanks for catching that. The bleeder valve is at the upper hose fitting I think
-Shawn
'91 Civic DX sedan
thermostat instalation-Villager 95 vlad ciobanica Villager 1 10-16-2006 04:19 AM
thermostat install tip 97taurusdude Taurus | Taurus Wagon 0 10-16-2005 12:48 PM
91 jetta thermostat installation norfull Scirocco 1 05-21-2005 10:36 PM
Thermostat Installation on 91 S-10 w/ 2.8L V6 pureplayinj18 S-10 13 03-08-2005 01:35 AM
Thermostat installation Snoopyusa5 Cavalier 0 05-25-2004 11:06 AM
