Old 04-28-2003, 12:00 AM
VelocityCivic91's Avatar
VelocityCivic91 VelocityCivic91 is offline
Send a message via AIM to VelocityCivic91
Question B16a1 Axels?????
Ok... I was at my friends house over the weekend in St. Pete, and him and I took my car to go to the local Saturday night "races". On our way out, I noticed that everytime I take off from a dead stop, there is a clang noise comming from my drivers side wheel. The harder I take off, the louder it is. I told him I was going to check it out when I get to my house. So today, when I got home, I jacked up the front of my car and looked under the drivers side wheel. Sure enough it was my axel. The boot was totally slit open (I knew this for a while... I really dont mind the clicking when I make a turn under power...). But when I grab the axel with my hand, it kinda has some play in it when I move it side to side. My dad says that the axel will not last long, and I need to replace it asap. Ok, this is where it gets weird... The guy I bought the car from said that axels had to be custom made for that motor. He said that a new axel would have to be cut in half, then re-welded. I asked a local import performance shop if that was true about B16 axels... the guy I talked to said he has never heard of that before, and the guy that told me they need to be cut and re-welded, was full of shit. Now while I was up under the car, my dad pointed out that it looked like my drivers side axel had been cut and re-welded back together.
I was told that axels from a 90-93 Integra LS will fit. My question... do they really have to be cut and re-welded, or do the 90-93 Integra LS axels fit with no problem??? My dad recomended me to go to this shop in town called Driveshaft Specalists. Shound I go to them or what???
Has anyone ever changed their axels on there B16a1? What did YOU have to do? Any help is greatly appericeated! :flash:
Here is a pic I took to prove that my drivers side axel has been modifyed... sorry its kinda dark, but you can make out the weld.
WARNING: Surgeon General says it's O.K. to smoke V-8's.
*** Looking for a B&M fuel pressure regulator and guadge***
Old 04-28-2003, 12:36 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
www.hasport.com go there they have a whole article on what axles to use in what combo with intermediate shaft. if u understand that article and can do u yourself, then no need to go to the driveshaft shop
Team Lonely Drivers
B16EJ1's Avatar
B16EJ1 B16EJ1 is offline
Re: B16a1 Axels?????
That axel looks terrible. The Teg axel is what should have been used when the swap was performed. If you have a SiRI B16 the 90-93 axel is used. If you have an SiRII B16 use the 94 up Teg axels.
Old 04-28-2003, 01:23 AM
OK, so NO modifying is involved, correct?
Old 04-28-2003, 01:28 AM
B16EJ1's Avatar
Nope. Get one from your local auto parts store for about 70 bucks and pop that shit in. No ghetto welding required. Also not sure if it makes a difference but I know I had to use the LS axels and also a friend I have used the same.
Old 04-28-2003, 01:41 AM
Thank you very much B16EJ1... I will get the drivers side LS axel tomarrow.
Why do you think that the axel I got in my car now was welded? Is it because it was the wrong size, and the dude was to lazy to just go out and get a 90-93 Ls axel?
Old 04-28-2003, 08:53 AM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
The axle in your car now is probably the one it came with when it was shipped. I guess real Si-R axles don't fit US cars or something.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 04-28-2003, 01:10 PM
Jmunk Jmunk is offline
Send a message via AIM to Jmunk
What kind of mount kit is in your car ?
Old 04-28-2003, 01:30 PM
rosman4u rosman4u is offline
I've also been told by many 86-89 integra axles work alot better depending how the engine falls in, meaning if its off by cm's or mm's it'll sit more flush, will let you know cause im installing my b16a this week on my 88 dx hatch.
Old 04-28-2003, 02:43 PM
I've heard 88-93 Integra axles were all the same, maybe it was 86-93. But anyhow they are supposedly the same thing. I don't doubt it because I have 90-93 on my ZC which is like the 88-89 Integra engine, so I bet they are all the same.
Old 04-28-2003, 03:42 PM
Kunundrum's Avatar
Kunundrum Kunundrum is offline
Send a message via ICQ to Kunundrum Send a message via MSN to Kunundrum
when using 90-93 teg axels you need to remove a spacer on the outer join... simple screwdriver... and if it's not done already remove the dust seal from the hub.
SiR Axels fit No problem... No modifications needed AT ALL.
86-89 axels are different.
In a perfect world you would want a axels with a 90-93 inner joint, 86-89 shaft, and Civic Si outer joint.
but in a pinch a teg one will work
K-
2012 VW Golf 3 Door Automatic (Company Car)
2011 VW Golf Wagon 5 speed (Company Car)
2010 VW Jetta 2.5 Automatic (Company Car)
2009 VW City Jetta 5 Speed (Company Car)
2009 VW GLI 6 Speed (Company Car)
2008 VW Jetta 2.0T 6speed (Company Car)
1999.5 Audi A4 Quattro Sport 1.8t (Chipped 1.0 bar) Sold
1990 CRX Si (Built B17a) - Stripped and Crushed
1988 CRX Si -- Stolen
1990 Civic Cx -- Sold
1990 Civic Si -- Parted
1989 Civic dx -- Sold
Old 04-28-2003, 04:01 PM
Fishcat37's Avatar
Fishcat37 Fishcat37 is offline
Send a message via AIM to Fishcat37
Ok - If you have the YS1,J1, or S1 intermediate shaft - then you can use the 90-93 teg axles.
If you have the Y1 SiR intermediate shaft (like me), then you can use modified 86-89 integra axles (we used some SiR axle parts).
FLINT BLACK 1990 CRX SI
Appearance Mods:
-JDM EF8 CR-X SiR Spoiler
-94/95 Integra GS-R rims
Performance Mods:
-JDM B18C swap
-OBD1 conversion
-Chipped P28 ECU
-Skunk2 Intake Manifold
-DC Sports 4-2-1 Header
-MSD SCI-L ignition
-EXEDY Racing Clutch
Interior Mod
-'95 Integra GS-R Gauge Cluster
Former Motors - RIP:
-JDM B16A #1- Blew up due to over-revving
-JDM B16A #2 - Hydrolocked
Former Cars
'89 CRX Si - "The Bumblebee"
'94 Integra GS-R
'96 Camaro
Old 04-28-2003, 05:44 PM
if u just go read the article on hasport, it explains everything, seriously u should go read it
Team Lonely Drivers
Old 04-28-2003, 06:00 PM
B16EJ1's Avatar
You're gonna confuse the guy but you are right. My friend has the YS1 tranny and I have an S80 tranny and the Teg axels work on both.
Need help identifiying jdm b16a1 sensor! zipperheadk Engineering/ Technical 12 03-13-2008 01:27 AM
What Is Needed To Get B16a1 Into High 13's All Motor? UMREX '71-'87 Civic | CRX 14 03-11-2002 12:37 AM
b16a1 in 5th gen. hatch? Poweredbyhonda '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 9 02-19-2002 11:20 PM
