Old 04-28-2003, 12:31 AM
strodda strodda is offline
stage2 cams
im debating whether to get stage1 or 2 cams. if i do get stage2, ill have to replace the stock internals. would replacing the springs be enough? or do i have to get new valves and retainers as well?
also, since the cams are basically the same price no matter what stage i get, is it worth getting stage2 and paying extra to upgrade the valvetrain? how much gain would i see over stage1's? btw, i was planning on getting skunk2's.
Old 04-28-2003, 01:22 AM
liquid8 liquid8 is offline
Send a message via AIM to liquid8
they recommend you get dual valve springs and titanium retainers. at the most probably 10 more hp but it would effect your daily driveability a bit.
"life's a bitch but god forbid the bitch divorce me" - nas
Old 04-28-2003, 01:51 AM
a friend of mine has skunk stage2's in his itr and he said it still drives normally. i was looking at crower and they have a version of their stage2 cams with a stock idle lobe, maybe ill get those instead. btw, would getting a spring/retainer kit raise the rpm limit?
Old 04-28-2003, 07:31 PM
not by itself. you would have to get an ecu or find some way to raise it. and they also suggest getting a fuel pressure regulator and a vtec controller (if you have vtec) and if not then an safc. because you have to tune it to get the most gains.
Old 04-28-2003, 10:02 PM
TheRebirth TheRebirth is offline
Banned
i heard crower stage 2 was a good setup from the guys at h22a.org
Old 04-29-2003, 01:28 AM
is that whats in the accord in their vids?
i know replacing those parts wont change the ecu's rev limit, but i plan on chipping it. what i meant was, will the valve kit raise the power curve/rpm range in which the motor can safely run. like right now, i could rev to 8k if i wanted, but i would just blow the motor. btw, i will be getting the apexi v-afc
Old 04-29-2003, 07:38 PM
it would eliminate the chance of valve float. so it would let you rev higher but i don't know how bad your r/s ratio is and that plays a factor also if you want to be able to rev high and still be reliable. but like a on a motor that had a good r/s ratio and the springs retainers and cams you would be able to rev really high. what motor do you have???
Old 04-29-2003, 08:37 PM
Banned
I believe so.
Old 04-30-2003, 12:13 AM
well i still have the f22, but ill be getting a h22 within a couple months. im just deciding on what to get, so i can have it installed with the motor.
Old 05-02-2003, 01:01 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Skunk2 stage 2 cams will be just fine for daily driving but yeh i would upgrade the valves, valve springs and retainers. About higher rev it would require more work then just a chip ecu , upgraded fuel. U need to mess around with the bottom end and the crank.
Old 05-02-2003, 01:43 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
damn strodda ... your headlights are looking good! You should come to the bay area meet in Livermore on May 10th at the in n out by office depot ... it starts around 2.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 08-19-2004, 06:44 AM
daweghound daweghound is offline
Re: stage2 cams
can anyone please tell me the degree settings for skunk stage 2 cams ?intake and exhaust?didnt come with cams please please help me
Old 08-19-2004, 03:20 PM
Ace$nyper's Avatar
Ace$nyper Ace$nyper is offline
Banned
Send a message via AIM to Ace$nyper Send a message via MSN to Ace$nyper Send a message via Yahoo to Ace$nyper
Re: stage2 cams
you dig up a year old thread for that good fucking job please leave you've embarrsed your self enough already
Old 08-19-2004, 03:31 PM
CivicSpoon's Avatar
CivicSpoon CivicSpoon is offline
There is no Spoon
Re: stage2 cams
hmmmm...maybe check their website, there's an idea.
Old 08-20-2004, 06:27 AM
Re: Re: stage2 cams
if you cant help shut your face ace!!!!!!!!!!
is there anyone out there that can supply me with the factory specs for stage 2 skunk cams?would be much appreciated no more dipshits like ace please
thanks
ps;ive tried there web site no luck and they wouldnt respond to my emails
Overhead Cams sedqp5 Classic Cars 2 11-10-2010 09:52 PM
Quad-cam Query?????? RVZ05 Escape | Maverick | Escape Hybrid 0 07-05-2010 05:47 AM
Pontiac GA Cam position sensor LOCATION ? cigars99 Grand AM 6 07-11-2009 11:30 AM
FS: 17" adr stage2 and nankang ns1 yelow88crxsi Wheels/Tires/Suspension 4 08-20-2004 01:33 PM
