Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 11-10-2010, 09:28 AM
sedqp5 sedqp5 is offline
Overhead Cams
Hello,
I am a mechanical engineering student at Mizzou and recently we have be studying cam design. Of course this led me to look into the internal combustion engine where I ran into a question.
I've noticed that it seems that people are moving away from pushrod cam systems to overhead cams but I'm not exactly sure why. I guess that I understand that by removing the push rods it frees up some logistical space in the lower portion of the motor but is there any advantages other than this?(i.e. advantages in available cam design such as to minimize acceleration or jerk?)
I was also wondering if there are any engine manufacturers who are utilizing form-closed cams rather than the standard seeing that this would eliminate the need for valve springs.
BTW, this information isn't for a project or anything, just curiosity, It's nice to see how this information is getting applied from time to time.
Thanks in advance
Old 11-10-2010, 11:40 AM
maxwedge maxwedge is offline
A990 racer
Re: Overhead Cams
Lots of weight savings with ohc also less moving parts and no deflection or odd angles in the valvetrain. The belt drive and gears can be complex and expensive though. Variable cam timing is the big thing now for power and economy, but also adds to complexity.
Old 11-10-2010, 08:52 PM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Overhead Cams
Overhead cams give 3 important advantages over pushrod engines.
1. It is an effective way to get the intake and exhaust valves facing each other at a canted angle. This allows for a hemispherical combustion chamber, which is more thermdynamically efficient. It allows for a more efficient burning of the fuel/air mixture, to increase power and fuel economy and reduce emissions.
2. This valve arangement produces greater volumetic efficiencies, allowing more air in and out of the combustion chamber for more power and fuel efficiency.
3. Overhead cam designs allow for less valvetrain mass, allowing for a higher-revving engine and the potential for more power. The engine can rev higher, with softer valvesprings, before valve float occurs.
You should note that some engine designs allow for some, but not all of these advantages. Some engines, like the Chrysler Hemi use pushrods, but get a hemispherical chamber shape. But they cannot rev as high as many OHC engines.
Also, some OHC engines , like the older Chrysler 2.2 ad 2.5 liter engines do not use the opposed-valve arrangement. They use valves lined up in a row and a resulting "wedge" shape chamber, like most pushrod engines, This allows for a higher rev potential, but does not allow the efficient hemispherical shape.
As noted above, all things being equal, pushrod engines are cheaper to manufacture, and are more compact.
Finally, an OHC engine allows for the potential of these advantages. But all components must have a coordinated, optimal design to gain them. It is quite easy to have a real dog of an OHC engine (the older Ford 2.3 4 cyl engine comes to mind) but some pushrod, wedge engines can be awesome, such as many recent Corvette engines.
the 1998 16 valve dual overhead cam 4 cylinder hyundai tiburon tiburonfrenzy Tiburon | Tuscani 1 03-11-2005 12:50 AM
dual overhead cam question lancerlady03 Lancer 9 10-31-2004 01:39 AM
Twin overhead Cam motor Adri fs23 SC/SL/SW 6 02-06-2004 03:08 PM
1995 ford 4.6l dual overhead cam KEVINS800 General Discussion 0 02-25-2003 06:54 PM
Dual overhead cam engine - V8 Rick Berg General Discussion 1 01-01-2002 11:20 PM
Tags
cams , ohc , push-rod
