Old 04-25-2003, 02:23 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
advancing and retarding a cam
Alright, anyone want to explain to me real quick exactly what retarding and advancing and cam does to the car/engine/perfomance. I am putting in a cam and camshaft right now and I can't recall exactly what that does. Thanks
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 04-25-2003, 02:24 PM
and whats the cam gear going to do for me as far as improvments, i bought it off a friend for 30 bucks AEM cam gear and si camshaft, so im putting it on right now and then taking off the cam once i get the si to put on the si.
Say NO to Primer!!
Old 04-25-2003, 02:25 PM
kaoru-tochiro's Avatar
kaoru-tochiro kaoru-tochiro is offline
Banned
my friend did that to bend his valves, it was soooo cool.
Old 04-25-2003, 02:26 PM
bend his valves?????????? explain
Say NO to Primer!!
Old 04-25-2003, 02:35 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Hi, Lisa.
When you set the timing on a car using a timing light, you are advancing or retarding the spark, changing the 'time' when the spark comes to the plug. I believe that retard means to have the spark come after the piston has hit top dead center (TDC). Advancing the spark means having the spark come before the piston reaches TDC.
Changing the cam will change how far the valves open up, and how long they stay open, and how fast they close. Changing the cam will not in anyway change 'when' the spark comes to set off the explosion in your cylinder. That adjustment is made at the distributor.
I'm sure someone here understands it better than I do. If I've made a mistake, please correct me.
Flunky
Old 04-25-2003, 02:43 PM
AF Premium User
PS-If the lobes are too tall on the cam your are installing, they will push the valve open so far that it will strike the piston when the piston gets to TDC. When a timing belt breaks, this is also how valves get bent, by making contact with the piston. Being at the wrong place at the wrong time=Damage.
Fllunky
Old 04-25-2003, 02:54 PM
thanks flunky, well obstacle #1 my boyfriend, hes doing this with me as we speak, forgot that your not supposed to take the four bolts at the top out because then the rocker assembly falls apart, so it fell apart, now hes having a hard time getting it to directly come together without any little space,
i have an extra rocker arm assembly from a blown dx but im pretty sure nothing was wrong with the rocker arm assembly, but its pretty old, in the way that its been sitting for a long time, any reason why i cant just put this on my dx, obviously i should clean off the old dried up oil and lube it up with new i suppose. anyone know???????????????/
Say NO to Primer!!
Old 04-25-2003, 03:23 PM
AF Premium User
There's nothing wrong with using the other rocker assembly.
Flunky
advance or retard? 1PhatCX '88 - '91 Civic | CRX | Wagon | Shuttlee 13 02-03-2005 12:03 PM
timing advance or retard AEM C!V!C '92-'95 Civic | EL | Civic Hybrid | Civic GX NGV 7 12-07-2004 05:06 AM
Ridiculous And Retarded Tickets 3000GT_Formula_350 3000GT/Stealth 39 09-25-2004 09:10 PM
Advanced or Retard Rotation Brandon2350 General Discussion 1 06-20-2003 08:48 AM
SOHC Cam Sprocket Advance or Retard? Frostbyte Engineering/ Technical 15 10-11-2002 10:51 AM
