Old 04-25-2003, 11:57 AM
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
Question Removing entire front dash
-Sup fellas,
pretty soon i'll be removing my entire front dash to get it re-upholstered and the plastic peices sanded/primered, then painted. But i dont know the steps to removing the entire thing. Im sure i could do it myself and figure it out.. but i always end up taking peices that dont need to come off and waste time. I was wondering if anyone knew a website w/ a how to on it, or could explain it to me. Thanks guys, and when i get to it, i'll post some pix of the finished product !
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
Old 04-25-2003, 07:32 PM
no one knows how to remove dash ?
Civic - Trashed it
Old 04-25-2003, 08:18 PM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
fellas huh? There are two girls on here also! j/k girl to the rescue..sorta
Anyway for one thing its hard to explain how to remove the dash, plus looking here in my chilton i guess its a little different for sedan, and im not a sedan owner, so all i can tell you is remove the center console first by just looking for the visible screws, then take out paneling around your cluster, take off upper panel by the two bolts on top toward front of car, and then the rest of it by the four bolts more on the inside by the actual cluster, lets see then remove vents, but be careful i guess your side vents are held by clips from underneath so hopefully you dont break those, and then the bolts that actually mount your dash there should be two on the very sides of the dash under the side defrosters, there should be one on the inside of the glove box on the right side, one in the middly where the bottom of your center console used to be, and one on the left side underneath where your fuse box is, then there should be some sterring column mounting bolts somewhere in there (i dont remember dealing with this part but then again someone was doing this with me) but from diagram they should be where u removed your gauge cluster, and then before actually physically trying to pull it out really check over and make sure you didnt miss any plugs, you dont want to break a plug, which is why you have to remove everything that serves a function because it has to connect somewhere i.e. power door switch, clock, climate control, rear defroster, cruise control etc. hope it helps if you attempt and get stuck i could always try to scan what i have from chilton but that is a pain in the ass so only if you get stuck
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 04-25-2003, 08:38 PM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
not too late to change that ... might be easier to find one of those "DX special edition" sedans with the sunroof than the si hatch / crx
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 04-25-2003, 08:49 PM
90civicrider's Avatar
90civicrider 90civicrider is offline
www.DecepticonRacing.com
Removing Dash = Death
haha just kidding, but it is a HUGE pain in the ass.
I dont have time to explain now, but i will when i get home from work.
||JEFF| |
Candy Orange 1990 Honda Civic H/B
Old 04-25-2003, 09:05 PM
lol
Say NO to Primer!!
Old 04-25-2003, 11:24 PM
thankz LuckyLisa, i'll try that out 2mar'o. Would today. But im here in G.A , and i couldnt get on til bout 10PM cuz we had bout 3 tornados touch down in my county !!! Crazy, ,reminded me of "Perfect Storm" when 2 storms combined.. but that made it go south from heading straight for me ( kennesaw ) it was crazy. The touchdowns were only bout minute each or somin.. but huge stoms, hail , etc.
So i'll try to get to that 2mar'o , providing more tornados dont pass by
Civic - Trashed it
Old 04-25-2003, 11:25 PM
tbk49's Avatar
tbk49 tbk49 is offline
Send a message via MSN to tbk49
I should really make a how-to on this, ive done its so many damn times heh, ill explain tommorow when i have time...
blah
Old 04-26-2003, 12:19 AM
Matt_SC Matt_SC is offline
Here's some scans:
Here's the 4 pages of dash removal from the manual. This is 90-91. I think the instrument pod removal may be different for 88-89.
http://www.duke.edu/~mjp10/dash/dash1.gif
http://www.duke.edu/~mjp10/dash/dash2.gif
http://www.duke.edu/~mjp10/dash/dash3.gif
http://www.duke.edu/~mjp10/dash/dash4.gif
Old 04-26-2003, 12:20 AM
aww how nice of you it would of taken hella long for me to scan
Say NO to Primer!!
Old 04-26-2003, 02:34 AM
Re: Here's some scans:
- well damn, that is good enough for me ! Thats great. Thanks alot again. Thanks guys ! hehe.. and u too LuckyLisa.
Civic - Trashed it
how do i remove the front dash on a 93 cadi509 Deville 0 07-05-2009 08:25 PM
Fairmont climate control - Help removing front dash cover. zeggawong Falcon | Fairmont | FPV 0 07-04-2008 11:33 PM
86 LeSabre Dash removal (new front spks) homncruse LeSabre 6 11-08-2004 11:55 PM
Removing front dash cover... tarrant77 LeSabre 9 10-15-2004 02:34 PM
00 Camry Front Dash Speakers: What Size And How To Remove? TEAM KLR Camry/Camry Hybrid/Vista 3 09-09-2004 01:23 PM
