Old 12-08-2003, 03:52 PM
tarrant77 tarrant77 is offline
Removing front dash cover...
Hey guys. I'm a new member to the forums, and I'm really a beginner to the world of car modding.
I have a 1992 Buick Lesabre Limited
I just bought a sound system and most of my plans for having friends install it have fallen through, and I've just decided to give it a try myself. Before I break anything...
I want to get the front dash off so that I can get to the 4x6 speakers.
Can anyone tell me how to get it off, without breaking anything?(I mean the plastic piece at the top)
Old 12-08-2003, 09:28 PM
Gerald K4NHN Gerald K4NHN is offline
Re: Removing front dash cover...
I don't have a 92, but I have a 88 and it has a piece that goes all the way across the top, close to the wind shield. It just snaps in place.
Good luck
Gerald K4NHN
Cayce, sC
Old 12-08-2003, 09:42 PM
file13stuff file13stuff is offline
I also do not have a '92, but on my '94 I had to start by taking the vents out and removing the screws that were behind them.
Hope that helps.
Old 12-17-2003, 04:30 PM
HannabilRox HannabilRox is offline
I have a 1990 LeSabre, and you remove the long plastic vent piece from the top of the dash (just is a pressure fit, so it snaps out). Remove 5 screws along the underside of the dashpad (one to the left of the steering wheel, one to the right, one by the radio area and two by the glove box). Then there are 5 screws inside the dash where you removed the long plastic vent piece that point down and towards the front of the car. It is a tight reach, so chances are you will be hitting the glass with your hand as you unscrew these. After removing all 10 screws, you will need to put the gearshift in D or 1 then slide the dash forward. Before pulling it all the way out, on the left side underneath, slide out the dash light lens for the headlight switch/dimmer, or remove the light socket. The dashboard should be free to remove. A Torx 15 screwdriver should be all you need! The speakers are mounted on either side face up.
Old 10-14-2004, 04:07 PM
OniEmu OniEmu is offline
I also have a '92 LeSabre Limited, how did you get the dash vents removed to get at the radio?
Old 10-15-2004, 04:18 AM
homeskillit37 homeskillit37 is offline
re
http://www.carstereohelp.com/stereor...ickLeSabre.htm
take a look at this site to get the dash apart to put in a new head unit. gives good advice. not sure about the speakrs though.
Old 10-15-2004, 07:00 AM
thanks
thanks, I tried it, but i cant get the vent to release from the panel. Any help?
Old 10-15-2004, 07:33 AM
rustbucket rustbucket is offline
Ditto HannabilRox, Ive had mine out many times on my '87.
Old 10-15-2004, 09:03 AM
re
to remove the vents i turned them to where the left side is sticking out as far as it will go and the right side is pointed in the dash. then i used a small screwdriver to pry the vent out.
Old 10-15-2004, 02:34 PM
Thanks a lot!! This really helps out
