Go Back   Automotive Forums Car Chat > Motorcycles & Choppers > Street Bikes
Old 02-24-2003, 07:15 AM
Scott 02's Avatar
Scott 02 Scott 02 is offline
Banned
Send a message via AIM to Scott 02 Send a message via Yahoo to Scott 02
quite a pretty pickle
anyways, what kind of bike do you suggest for the bike newbie then?
Old 02-24-2003, 08:52 AM
speediva's Avatar
speediva speediva is offline
Send a message via AIM to speediva Send a message via Yahoo to speediva
Like I posted before, if Grendel wants a bike that looks faster than it is (a small sportbike is what I read), then he ought to look into buying a used Ninja 250. Many many people buy 250s and outgrow them in a year or two, so used won't be a problem to find. Also, by taking the MSF course, they may be looking at buying new bikes for the course and he could either buy one of the bikes they are getting rid of, or ask them if he can get in on the deal of the mass purchase.
Like a boy - but BETTER!
2005 Subaru Forester 2.5X
1997 Honda Civic EX Coupe
Inform yourself:
AF User Guidelines
Old 02-24-2003, 09:57 AM
R1-rider's Avatar
R1-rider R1-rider is offline
Send a message via ICQ to R1-rider Send a message via AIM to R1-rider
Front Motor Mount System in all 1997 - 1998 models;
Negative Battery Cable in 1996 - 1998 S1 Lightning and 1998 S1 White Lightning models;
Rear Brake Line in 1999 Lightning X1 models;
Side Stand Switch in all 1996 - 1999 models, except S2 and S2T Thunderbolt models;
Fuel Tank Retention System in all 1995 - 1999 models, except Lighting X1 models;
Fuel Tank Vent in all 1995 - 1999 models;
Swing Arm in all 1995 - 1998 models;
Models:
Buell S-1 Years: 1996-1998
Buell S-3 Years: 1997-1998
Buell S-3T Years: 1997-1998
Buell M-2 Years: 1997-1998
Buell S-1W Years: 1998
Description of Noncompliance: Failure of one or more turn signal lamps would not be indicated to the operator of the vehicle (no noticeable change in the flashing rate of the turn signal indicator light). This does not meet the requirements of FMVSS No. 108, "Lamps, Reflective Devices, and Associated Equipment."
Consequence of Noncompliance: An operator would not be aware that the turn signal lamps were not working increasing the risk of a crash.
Models:
X1 Years: 1999
M2 Years: 1999
S3 Years: 1999
Description of Defect: The swing arm on these motorcycles was improperly manufactured. This condition can cause the rear suspension to fail without warning, leading to loss of control of the motorcycle.
Models:
Buell S1 Lightning Years: 1996-1998
Buell M2 Cyclone Years: 1997-1999
Buell S3 Thunderbolt Years: 1997-1998
Buell S3T Thunderbolt Years: 1998-1999
Buell S1 White Lightning Year: 1998
Buell X1 Lightning Year: 1999
Defect: These motorcycles were built with a sidestand switch that could become inoperative, causing the engine to stall or quit when riding.
Models:
Buell S1 Lightning Years: 1997-1998
Buell S1 White Lightning Years: 1997-1998
Buell M2 Cyclone Years: 1997-1998
Buell S3T Thunderbolt Years: 1997-1998
Defect: On certain motorcycles, the rear brake line can chafe, resulting in loss of brake fluid. Should this occur, the rider could experience loss of rear braking capabilities.
Models:
Defect: On certain motorcycles, motion of the battery cable can lead to breakage of the battery terminal. This condition can cause the engine to stall or quit when riding.
Models:
Buell S2 Thunderbolt Years: 1995-1996
Buell S2T Year: 1996
Defect: These motorcycles were built with a rear shock absorber front eye that could break. If the shock eye should break, the underside of the vehicle will drag on the ground, possibly causing loss of vehicle control.
Models:
Defect: These motorcycles were built with a swingarm that could break. If the swingarm should break, loss of vehicle control could occur.
Models:
Buell S3 Thunderbolt Years: 1997-1999
Defect: These motorcycles were built with a fuel tank vent valve assembly that could become plugged. Under certain conditions, this could cause the carburetor to overflow fuel, which could result in a fire. This condition could also prevent sufficient fuel flow, which could cause the engine to misfire or stall.
Models:
Defect: These motorcycles were built with a fuel tank mounting system that could, in the event of a crash, allow the fuel tank to separate from the motorcycle.
Models:
Buell M2 Cyclone Year: 1999
Defect: Certain motorcycles were manufactured with an incorrect air cleaner component. This component could restrict air flow into the float bowl of the carburetor, causing fuel to overflow, which could result in a fire. This could also prevent sufficient fuel flow, which could cause the engine to misfire or stall.
Models:
1999 Buell S3 Thunderbolt motorcycles,
Defect: The location of the rear brake line can cause it to become damaged and leak fluid. A loss of rear wheel braking capabilities could occur, increasing the risk of a crash.
Models:
2002 Buell M2L
2002 Buell S3T
2002 Buell M2
2002 Buell X1
Defect: These motorcycles were built with a front shock mount that is cracked and could break.
Models:
2003 Buell Firebolt XB9R
Defect: On certain motorcycles, the side stand legs have the potential to bend or break.
hehe, have fun with that one for awhile.
......or if your a loser who drives a Civic with a type R sticker, racing stripes, blasting really bad rap music through your suburban area with your pretentious "I’m 21 but I’m still in high school girlfriend" while driving with your hand up on the top of the steering wheel exposing your underdeveloped pasty white vitamin deficient arm and wearing your backwards BS upside down visor hat while feeling the tacky as a "Florida vacation" single diamond earring in your ear, If you are this person...with any luck the sun in its precise celestial positioning as you putter on by...will reflect its scorching rays into your earring, bouncing intensely in your rearview, and finally making contact with your eyes through the thin cheap lense of $5 gas station Oakley rip off glasses.. then burning your retnal cones into smoldering melting gobs of ocular material as you are blinded by the purest form of energy in our known universe, and as you scream no one can help or hear you because they don’t know what’s going on since the weed whacker sound of your shitty tiny little muffler which makes the Civic sound like a 747 rages on underneath making everyone turn at disgust and comment to thier husbands or wives how much of a dickweed you are by attaching that automotive abnormality to your stock economical daily driver engineered by Japanese Automotive specialists to fit the needs for entry level business workers in their early 30's, however your pathetic looking $11,000 car which you want to look like a friggin spaceship with redundant ground effects is now out of control since you are blinded, and as your car plunges off the side of a cliff while you scream in the purest form of terror while knowing you have lived a horrid excuse for a life, by doing the bare minimum in every facet of existence, while getting fired from one pathetic job to another, the majority of your time spent slacking smoking dope, getting kicked out of school, polishing your "game" on sweet innocent underage girls you eventually 'de flower' through exhaustive yet succesful attempts to get the date rapist drugs you have stashed in the glove compartment, into your poor victims drinks while offering them to take the "Pepsi Challenge" while making your mother hate you, and your poor father who wishes he had a daughter instead of your pathetic ass, since a girl would be more of a man than you ever were, like the occasion when you were hit in the arm by a wild pitch in little league, then you cried like a fat kid who dropped his ice cream cone, I'm already envisioning you impacting the rocks below, in a spectacular fireball ignited from the residue hairspray from your girlfriend plastered in the fabric passenger seat, blinded by your earring, deafened by the loud "Bling Blingin", and I will smile and roll around on the ground in orgasmic delight while you are consumed by flames whose intense heat and fury will liquefy your bone marrow that I will use to make jelly beans out of and eat them happily at your funeral as midgets dressed like Alex 6005321 from "A Clockwork Orange" dance around your coffin to loud industrial style techno music and strobe lights, and I will sleep soundly at night knowing another successful conquest of Darwinism has been attained.
Old 02-24-2003, 11:16 AM
speediva's Avatar
Models:
X1 Years: 1999
M2 Years: 1999
S3 Years: 1999
No shit, "leading to loss of control of motorcycle"!!! You really aren't going anywhere w/o a properly assembled DRIVE WHEEL!!!
Models:
Not only loss of braking capabilities due to no BRAKE FLUID, but also leaking lubricant all over the flippin road leading to loss of traction on your wheel. Gee, wouldn't that just be fun???
Models:
Defect: These motorcycles were built with a rear shock absorber front eye that could break. If the shock eye should break, the underside of the vehicle will drag on the ground, possibly causing loss of vehicle control.k
POSSIBLY causing loss of control???? You must be shitting me!!!
Models:
Again, loss of control COULD?!?! occur! hahaha. Good joke!
Models:
Again, the loss of brake fluid isn't the biggest factor here. 75-85+% of your stopping power on a motorcycle is in the front brake, but you are in much deeper shit if your rear wheel gets nasty, slippery brake fluid all over the damn thing. It'd be like riding on sheer ice!!!
Buell has more recalls than Ford, Chrysler, and GM combined it seems!!!
Inform yourself:
AF User Guidelines
Old 02-24-2003, 11:49 AM
Scott 02's Avatar
Banned
OMG, I don't care...Thats alot of Bull SHIT and HELL BE GOD DAMNED IF I WERE TO EVER GET A IMPORTED BIKE! You 2 make Buell look so god damned bad. Hey Saturn, I don't know how you got into this thread, but personally I don't think you know crap about bikes. So stop agreeing with R1 Rider so you can sound good. He is the only one I believe not YOU! Im am getting very pissed of here lately.......
Old 02-24-2003, 12:55 PM
R1-rider's Avatar
Oh I see, so you are stuck on the whole notion that harley and buell are "American" made bikes? yet all or most of their mufflers, carbs, distributers and other components of the engine are imported from japan. Doubt me? And not to mention that Honda's Ohio motorcycle plant ALONE hires more AMERICAN citizens then all of harley and buell combined. So while you can be disallusioned by Harleys' PR department all you want, I will stick with a "japanese" bike which is more reliable, faster, better looking, less dangerous, and of course actually hires more americans then some harley piece of shit. And don't bash on saturn, she has not gone into the research as indepth as I have, but she still knows a good deal about motorcycles and is always willing to help people.
Old 02-24-2003, 03:16 PM
Scott 02's Avatar
Banned
Saying that b/c she is a mod. Im not scared of mods in the first place. Thats not the point though. I don't give a shit go with the damn japan bike. You didn't need to list all them fucking recalls. This thread should be closed. Sorry Grendel... you should get the picture now....
Old 02-24-2003, 04:56 PM
speediva's Avatar
Where is your research? I am a full time college student and haven't had the time to do the research that R1 has done. I would like to know where you get off believeing that Buell is such a die-hard brand. I hear the recalls on the nightly news, where do you get your info???
You want to mouth off to me, tell it to my 20 years of living with an avid rider for a father. I have a motorcycle. Where's yours?
Edit: I'm even helping you with the problems of my personal faves in Imports!!!
Yamaha's are known for poor wheel quality (i.e. cracking leading to breakage).
Triumph's have some that will not run after awhile due to electrical problems.
Aprilia have a problem with exterior pieces of fairings falling off or breaking.
Ducatis also may suffer from electrical problems after a period of time.
Inform yourself:
AF User Guidelines
Old 02-24-2003, 05:15 PM
Heep's Avatar
Heep Heep is offline
Send a message via AIM to Heep Send a message via MSN to Heep
Geez people, take it easy on Scott. He expressed his opinion, helped give Grendel an idea for a good beginners bike, and showed that he likes the product....then you all start bashing the bikes and him for liking and suggesting them. It's up to Grendel to decide what to get, Scott was just providing an option.
I happen to love Buells, they have a level of exclusivity and character most Japanese bikes can't match, and given proper maintenance will last just as long.
Side note, I hate it when people equate a high number of recalls with poor reliability. I highly respect brands that have the balls to humiliate themselves with a recall.....they're admitting the product has a problem, and that they are willing to fix every one on their expense to satisfy owners and keeps the roads a safer place. Most products without a high recall list are either using tried and true, yet antiquated technology and/or do not have the balls to issue a recall regarding problems that are guaranteed to happen with anything new.
________________________________________
Mark Brown
1991 Volkswagen Jetta (1.8L I4/5-speed/FWD)
Old 02-24-2003, 06:42 PM
Steel's Avatar
Steel Steel is offline
Or they're built right in teh first place, heep.
Im sorry but i dont trust harleys or buells as far as i can throw them. Which isn't far. Im skinny.
Anyway, i personally met my freinds uncle who is a parapalegic becasue whoever designed his harley decided it wasn't a bad idea to have the oil filter or oil plug pointing right at the front wheel, and to make the connection extra weak.
Old 02-24-2003, 06:53 PM
Heep's Avatar
Though there are some companies with better quality control than others, every single new part can only be properly tested after road use by average consumers, and whether or not they work perfect or fail is more or less luck of the draw. Aside from the quality the bike builders actually put into making the bike, not much else is really a factor in determining quality. Eg, I trust an American built part just as much as a Japanese built part, it all depends on the quality of the installation.
Anyways, lets not make this a discussion about quality.
Also, if you don't like Buells that's perfectly allowed, and feel free to express your opinion, just PLEASE refrain from insulting other members because of their choice or recommendation. Grendel just wants ideas of what bikes to look at, and he can do his own research into which is best for him based on a cost/reliability/servicing/how much he likes it basis.
Mark Brown
Old 02-24-2003, 07:33 PM
OneSicR6 OneSicR6 is offline
Send a message via AIM to OneSicR6
Originally posted by Heep
Also, if you don't like Buells that's perfectly allowed, and feel free to express your opinion.
To say I dislike Buells would be an understatement. While I agree that alot of companies need to nut up and recall some things, it's usually something minor though, like R6's have a leak prone battery that they won't recall, I never heard anything about reliability issues with the wheels though. But COME ON we're talking about a rear suspension that fails, OR a swingarm that can snap, these things tell me Buell either had piss poor engineering on these bikes, or they didn't spend enough time testing them out before they put them out for the consumers to buy. The brake fluid recall is minor, that's to be expected, you'll always have little things like that, I rarely even touch my rear brake anyway. I've ridden Buells before, I'm not going to bash them, let's just say it didn't impress me. Of course not too much that has Harley powering it really does. I also know people that have Buells that break down on a fairly consistent basis, and if I recall correctly parts are pretty expensive for them. I say go Japanese, you won't regret it, try and find an early 90's model and you should be able to find one in your price range and for those of you on your high horse because Buell is "American" lol, R1 Rider hit that nail square on the head.
"When in Doubt...Gas It!"
Old 02-24-2003, 08:33 PM
Scott 02's Avatar
Banned
Thanks Heep. I just stated some opinions and he is right about how R1 threw some recalls at me like that. Oh well, My opinion will not change.
Old 02-24-2003, 11:53 PM
R1-rider's Avatar
I don't mean to come off as offensive, but when somebody asks for my opinion I give it to them. My personal experience with Buells has been far from favorable, and my prejudice is a result. I in no way feel the need to try and change Scott's mind, however I don't want some poor sap reading the garbage he is writing to think that it is correct. When somebody asks for the best bike, I will give them either the best bikes I believe to get, or the worst ones to stray away from, obviously you can tell it was the latter in this case. Ofcourse this is in my own personal opinion, however do not take it lightly because unlike some people here, I know a great deal about what I am saying.
Old 03-02-2003, 01:38 AM
bvia's Avatar
bvia bvia is offline
Talking
A high number of recalls?...LOL...THE ENTIRE POPULATION!
As "balls to humiliate themselves with a recall"...NTSB FORCED Buell to do the recall...no respect should be given there other than they didn't sue to stop the recall...
I'm sorry, Heep. You just don't know what you are talking about.
Bill
What's a good bike with displacement of 100cc-250cc for a noob? )I(EHbKA Street Bikes 6 08-26-2005 10:05 AM
QUICK! Whats a good price for a new 04 cavalier tojomagic Cavalier 5 04-04-2005 04:29 AM
What is a good sport bike for a new rider -cy- Street Bikes 51 04-02-2003 08:38 PM
What is a good bike for someone with no experience? JE123 Street Bikes 2 02-22-2002 01:17 PM
